WARNING: Running pip as the 'root'
I’m encountering a warning when using pip as the root user on my system. The warning message is as follows:
WARNING: Running pip as the ‘root’ user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: 12. Virtual Environments and Packages — Python 3.13.0 documentation
It looks to be a warning. If it does not fail out, it may be ignored.
