Hi, I’m trying to add GANverse3D extension to Omniverse and I’m getting a warning sign without any warning/error information. This is not allowing for it to launch. I have attached the image for your reference.
I found a couple other forum posts where this may be addressed. To find these I searched for ganverse
and got these results: Search results for 'ganverse' - NVIDIA Developer Forums
I am using Omniverse 2021.3.8. I installed ganverse3d - image2car from Windows>Extensions. But when i try to run, it is showing me a RED Warning symbol(Screenshot attached)
[Ganverse3d error]
Hello @Tsluan , @burnpepper , @Manatoba , & @fsheng21 ! Thank you so much for your patience. The updated GANverse3D extension is now available for Create >= 2021.3.4. You can get it directly from the Extension Manager (Window->Extensions), searching for aitoybox and hitting the Update button. (Note that it may take several minutes to download, depending on your connection).
We will be updating the documentations shortly with instructions on how to obtain the extension as a zip file for anyone with …
(I also moved this post into the Omniverse>Developer
topic)
