So when I try to access the RTSP Stream generated by DeepStream, I am getting this Warning message.
I tried to find ‘pt’ keyword in the files, but have not been able to.
Can you tell me how to fix it?
GLib-GObject-WARNING **: 13:46:13.097: g_object_get_is_valid_property: object class 'GstUDPSrc' has no property named 'pt'
Hello can you tell me how did you fix your problem, i’m having the exact same problem using the python binding code.
Trying to do a RTSP streaming using a nvarguscamerasrc,
Everything works, but when i open VLC and try to connect to the URL I get the same error:
sys:1: Warning: g_object_get_is_valid_property: object class ‘GstUDPSrc’ has no property named ‘pt’
