I trained SSD_Mobilenet_V2_coco model with my own data set then i want to run my custom model on jetson nano. I converted frozen_inference_graph.pb to .uff as:
sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py ./frozen_inference_graph.pb -o ssd_mobilenet_v2.uff -O NMS -p ./config.py
Output of above command:
2020-02-13 22:54:07.807469: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Loading ./frozen_inference_graph.pb
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:231: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.12.0. Other versions are not guaranteed to work
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
WARNING: To create TensorRT plugin nodes, please use the create_plugin_node
function instead.
function instead.
UFF Version 0.6.3
=== Automatically deduced input nodes ===
[name: “Input”
op: “Placeholder”
input: “Cast”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
dim {
dim {
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_conf as custom op: FlattenConcat_TRT
Warning: No conversion function registered for layer: FusedBatchNormV3 yet.
Converting FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_5_3x3_s2_128/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_1_Conv2d_5_1x1_64/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_4_3x3_s2_256/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_1_Conv2d_4_1x1_128/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_3_3x3_s2_256/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_1_Conv2d_3_1x1_128/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_2_3x3_s2_512/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_1_Conv2d_2_1x1_256/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/Conv_1/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_16/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_16/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_16/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Warning: No conversion function registered for layer: AddV2 yet.
Converting FeatureExtractor/MobilenetV2/expanded_conv_15/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_14/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_13/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_13/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_13/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_12/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_11/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_10/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_10/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_10/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_9/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_8/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_7/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_6/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_6/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_6/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_5/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_4/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_3/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_3/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_2/add as custom op: AddV2
Converting FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/Conv/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Warning: No conversion function registered for layer: Cast yet.
Converting Cast as custom op: Cast
Converting FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_4/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_4/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_4/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_5/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_5/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_5/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_7/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_7/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_7/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_8/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_8/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_8/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_9/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_9/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_9/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_11/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_11/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_11/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_12/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_12/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_12/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_14/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_14/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_14/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_15/project/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_15/depthwise/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/expanded_conv_15/expand/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Warning: No conversion function registered for layer: GridAnchor_TRT yet.
Converting GridAnchor as custom op: GridAnchor_TRT
Converting concat_box_loc as custom op: FlattenConcat_TRT
No. nodes: 644
UFF Output written to ssd_mobilenet_v2.uff
what about these WARNINGS?
