Assume that there are no warp divergence or other strange conditions. Can I just seen __syncwarp() as a zero-cost operation? Can __shfl_sync() also be seen as a zero-cost operation?
__shfl_sync() has reduced throughput, relative to many other instructions, the amount varying with architecture. See here.
Also shfl uses some port hardware from the shared memory as far as I know, so it depends on what other instructions are executed at the same time.
This is generally true for Cuda: As long as you have a good instruction mix, you get a good overall performance, with mono-cultures of instructions you are creating a bottleneck, which may or may not be critical for your application.
So some __shfl_sync() are no problem; if you have a huge amount of them, they can be the limiting factor.
__syncwarp() is quite cheap and fast to do, but it is still an instruction, which has to be issued. So for a very fast program it could be limiting.
coupled with these other comments, when a sync operation is necessary for correctness, there is often no alternative. So the cost, whatever it may be, is necessary.
