Hi, I’m curious what the correct semantics of this piece of code is: Assume it’s being run over 64 threads. I’m also interested in what happens when the predicate gets more complicated.
The key point is that the vote is across all threads in the warp that are active. I believe that in your example, global_memory[1], global_memory[3], etc, should be true. global_memory[0], global_memory[2], etc should be uninitialized.
