My I2C bus appears to have failed
ValueError: No I2C device at address: 3c
I’ve been working with the Jetbot project, and the display is the same called for in the bill of materials (SSD1306. Adafruit Part # 3527)
The device has been working fine up until yesterday, when it simply stopped giving a display. Also the motor controller, which is connected to the same pins as the display, also stopped working at the same time
I tested the SSD1306 as being functional by installing it in a Raspberry Pi3 and running the same stats.py program that was in the Jetbot, and the display works on the Pi
Hi, did you check the output log info? Is the system dead and can’t power on or just the I2C failed? If latter, is it possible to try another I2C of Jetson? If system is dead, maybe you need to run RMA for the board
Yes, I have the log info. It just repeats over and over, so I’ll just post one section…
Oct 22 12:45:52 jetbot sh[3749]: TimeoutError: [Errno 110] Connection timed out
Oct 22 12:45:54 jetbot systemd[1]: jetbot_stats.service: Main process exited, code=exited, status=1/FAILURE
Oct 22 12:45:54 jetbot systemd[1]: jetbot_stats.service: Failed with result 'exit-code'.
Oct 22 12:45:54 jetbot systemd[1]: jetbot_stats.service: Service hold-off time over, scheduling restart.
Oct 22 12:45:54 jetbot systemd[1]: jetbot_stats.service: Scheduled restart job, restart counter is at 1.
Oct 22 12:45:54 jetbot systemd[1]: Stopped JetBot stats display service.
Oct 22 12:45:54 jetbot systemd[1]: Started JetBot stats display service.
Oct 22 12:46:21 jetbot sh[6971]: Traceback (most recent call last):
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
Oct 22 12:46:21 jetbot sh[6971]: "__main__", mod_spec)
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
Oct 22 12:46:21 jetbot sh[6971]: exec(code, run_globals)
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/local/lib/python3.6/dist-packages/jetbot-0.3.0-py3.6.egg/jetbot/apps/stats.py", line 36, in <module>
Oct 22 12:46:21 jetbot sh[6971]: disp.begin()
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/local/lib/python3.6/dist-packages/Adafruit_SSD1306-1.6.2-py3.6.egg/Adafruit_SSD1306/SSD1306.py", line 148, in begin
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/local/lib/python3.6/dist-packages/Adafruit_SSD1306-1.6.2-py3.6.egg/Adafruit_SSD1306/SSD1306.py", line 292, in _initialize
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/local/lib/python3.6/dist-packages/Adafruit_SSD1306-1.6.2-py3.6.egg/Adafruit_SSD1306/SSD1306.py", line 129, in command
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO-1.0.3-py3.6.egg/Adafruit_GPIO/I2C.py", line 116, in write8
Oct 22 12:46:21 jetbot sh[6971]: File "/usr/local/lib/python3.6/dist-packages/Adafruit_PureIO-0.2.3-py3.6.egg/Adafruit_PureIO/smbus.py", line 256, in write_byte_data
Oct 22 12:46:21 jetbot sh[6971]: TimeoutError: [Errno 110] Connection timed out
It does still power on, but, even if it did still work on a different I2C, that would still mean that the thing isn’t functioning up to par, and I’d much rather RMA it. I only bought it on June 1 2019, so still well within the warranty period
Nvidia responded, and agreed that the unit should be RMA’d
They emailed me a prepaid label to send the thing back, and they promise that it will be handled in 5 days or less
Thank you Nvidia
