Watch screen through Nomachine when Display Port is unplugged
Trying to see the screen of the Jetson (orin nano super) through Nomachine software (resemble to ssh), when it is connected to DP it is working very good but when I disconnect it, it makes problem and not working well. I need to work with the jetson in unplugged way on my robot and control it remotely.
How can I fix this ?
You may refer to the setup and try to apply to your use-case:
Jetson AGX Orin FAQ
Unfortanatly, even though it makes things work it destroy the connection to our IMX219 camera -
The error due to your guide is:
@ubuntu:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1280, height=720, framerate=30/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=1280, height=720’ ! nvvidconv ! nvegltransform ! nveglglessink -e
libEGL warning: DRI2: failed to authenticate
Setting pipeline to PAUSED …
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 93)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:318 Failed to create FrameConsumer
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:239 (propagating)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, waitRunning:201 Invalid thread state 3
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:849 (propagating)
Redistribute latency…
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
../libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:00:00.140261050
Setting pipeline to NULL …
Freeing pipeline …
The Argus stack and nvarguscamerasrc do not work in headless setup. Please refer to the discussion in the topic and use UDP:
Is it possible to run a GStreamer pipeline in headless mode with the source plugin nvarguscamerasrc? - #19 by DaneLLL
