Watch STL string value while debugging
Hi again!
In older versions of TADP there was possibility of examine std::string value while debugging, but after update to AndroidWorks I can’t see whole string’s value, but its first character only:
http://dl1.joxi.net/drive/0005/2399/366943/150926/3f8ca3bc0b.jpg
How to fix it?
Thanx in advance!
Hi Paltr,
sorry for the late reply. Could you check if the visualizers is there C:\Program Files (x86)\Microsoft Visual Studio \Common7\IDE\Extensions\NVIDIA\Nsight Tegra<version>\Debuggers\Visualizers\stl?
if not, please try latest release -Nsight Tegra Visual Studio Edition 3.2 and see if it solves the issue.
if not again,please attach the log files located at %AppData%\Roaming\NVIDIA Corporation\Nsight Tegra\Logs along with Visual Studio extended version.
Thanks in advance!
victor
Hi Victor,
Thanks for reply - better late than never :)
All the visualizer files are on the right places as I see. I updated Nsight MSVC plugin, but the problem didn’t solved.
Could you please tell us, what kind of compiler and STL library you’ve configured in a project’s settings?
I think the problem is with const string& txt, while std::string txt is ok, referenced value is not visualized.
Also you could try to switch to gnustl_static and see if the visualizers starts to work.
http://developer.android.com/ndk/guides/cpp-support.html
