after many tests with my 2 asus gb10 i think that a fully water cooled new housing would increase
power and stability very much.
As i own a fanuc robodrill machining center i have the idea to make a new water cooled housing.
I am thinking about a water cooled full copper plate on the top with a fancy stealth design and
Possibly a black anodized aluminium bottom plate with interlockable feet. and also some possiblity to mount it into a rack possibly on a 90 deg Angle.
If i understand correct the Nvidia DGX Spark and all its GB10 based variants share the same
mainboard and the integrators just add housing and cooling. Please correct me if i am wrong?
But if they share the same mainboard why do they have differenet manufacturer specifiy bios versions? Just to adapt cooling?
I am thinking to make the whole thing a little wider so it can fit M2. 2088 SSD memory and also cool it properly.
Possibly add some sensors for water flow and temperatures and a fancy led power switch.
Who would be interested in a housing like that? What else would you like to see in such a watercooled housing concept?
Best Regards
eh17
