I’m facing a problem reading gpio on a Jetson Nano with a Waveshare JETSON-IO-BASE-A carrier board.
I connect a jumper between PIN 11 (GPIO50) and PIN 1 (3.3V) with a 1K resistor, so that when the jumper is connected, I read a 1 and when the jumper is disconnected, I read a 0. On an official NVIDIA Nano Developper Kit, I have this behavior. With the Waeshare kit, whether the jumper is present or not, I always read 1.
I tried to modify the the dtb to force GPIO50 to PULL_DOWN on the Waveshare board but it didn’t do anything.
Is there a way to have the same behavior on both boards ?
