Hey guys
im trying to implement the Mandelbrot set using cuda , the convenional way of doing that is to implement the main core
which does what it has to do , and for each point in the set i should determine which color i should give it by number of iterations.
that’s all nice , but im trying to build a 3d model using polygons rather than simple pixels…
i’ve began exploring the VBO but something doesn’t make quite clear yet…
since im going to use GL_ARRAY_BUFFER which is going to each point’s X Y Z, Z- stands for number of iteraion by CUDA main kenrel function.
and for each point i should also save it’s color( RGBA ) - as you can see , if im working on 800*600 res the amount of points is huge :
8006003*4 → 3 stands for xyz and 4 stands for RGBA.
since preformence is CRITICAL my question is :
since the best way working with VBO arrays is by declacring a huge float,int array and registering it in the HOST and DEVICE + buffer etc…
or should i use classes and so on?
im asking it because of the following example i found over the net :
#pragma pack(push, 1)
struct SVertex
GLubyte r;
GLubyte g;
GLubyte b;
GLfloat x;
GLfloat y;
#pragma pack(pop)
glBindBuffer(GL_ARRAY_BUFFER, BufferName);
glBufferData(GL_ARRAY_BUFFER, VertexSize, VertexData, GL_STREAM_DRAW);
glColorPointer(3, GL_UNSIGNED_BYTE, sizeof(SVertex), BUFFER_OFFSET(ColorOffset));
glVertexPointer(2, GL_FLOAT, sizeof(SVertex), BUFFER_OFFSET(VertexOffset));
glEnableClientState(GL_VERTEX_ARRAY);
glEnableClientState(GL_COLOR_ARRAY);
glDrawArrays(GL_TRIANGLES, 0, VertexCount);
glDisableClientState(GL_COLOR_ARRAY);
glDisableClientState(GL_VERTEX_ARRAY);
as you can see here , i can declare on an array which contains both points and colors , i just need to setisfy the function with the correct offsets and so on
something which i cant do with classes for each point.
thanks all!!
