yes, I’m using latest version. I updated all of them. And, I changed refresh rates to 120hz. Now, It stucks with ~60 fps. It seems It works with Actual Refresh Rate / 2 on external monitor.
gny@fedora:~$ glxgears
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
305 frames in 5.0 seconds = 60.823 FPS
335 frames in 5.0 seconds = 66.949 FPS
299 frames in 5.0 seconds = 59.722 FPS
301 frames in 5.0 seconds = 60.041 FPS
299 frames in 5.0 seconds = 59.737 FPS
314 frames in 5.0 seconds = 62.614 FPS
303 frames in 5.0 seconds = 60.433 FPS
299 frames in 5.0 seconds = 59.651 FPS
327 frames in 5.0 seconds = 65.332 FPS
314 frames in 5.0 seconds = 62.633 FPS
