Hi. I’ve got a Jetson TX2 with Ubuntu 18.04, and I have Wayland running on it by booting into the console and doing this:
mkdir /tmp/xdg
chmod 700 /tmp/xdg
sudo XDG_RUNTIME_DIR=/tmp/xdg weston-launch
Weston seems to come up great, but when I run vulkaninfo it lists the below instance extensions. Note that VK_KHR_wayland_surface is not listed, and xcb/xlib are.
Is there any way to get this working? Thank you very much for any assistance.
-Mike
Instance Extensions:
Instance Extensions count = 13
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 21
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities: extension revision 1
VK_KHR_get_physical_device_properties2: extension revision 1
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VkPhysicalDeviceProperties:
apiVersion = 0x401055 (1.1.85)
driverVersion = 134234112 (0x8004000)
vendorID = 0x10de
deviceID = 0x93ba03d7
deviceType = INTEGRATED_GPU
deviceName = NVIDIA Tegra X2 (nvgpu)
