Ways of manual loop unrolling as a workaround to avoid unnecessary register spills
Recently I’ve hit a problem where compiler performs dull register spills to the local memory. The solution I found is to manually unroll loops. I remember someone long time ago mentioned that there is macros based loop unrolling technique which can simplify the task, but I couldn’t find it.
So, how do you unroll loops ?
Here is the kernel (compile with --ptx) causing problems:
#define INSERT_SORTED(j) \
  if (minval[j] > t) \
    float tt = minval[j];\
    float nn = minind[j];\
    minval[j] = t;\
    minind[j] = n;\
    t = tt;\
    n = nn;\
#define MERGE_SORTED(i) \
      sd[threadIdx.x] = minval[i];\
      if (k >= 32)\
        __syncthreads();\
      float t = sd[threadIdx.x + k];\
      sd[threadIdx.x] = __int_as_float(minind[i]);\
      if (k >= 32)\
        __syncthreads();\
      int n = __float_as_int(sd[threadIdx.x + k]);\
      if ((threadIdx.x & (k*2-1)) == 0)\
        INSERT_SORTED(0);\
        INSERT_SORTED(1);\
        INSERT_SORTED(2);\
        INSERT_SORTED(3);\
        INSERT_SORTED(4);\
        INSERT_SORTED(5);\
__constant__ struct
  int numvals;
  float*  in;
  float2* out;
} c;
__global__ void test_kernel()
  const int BLOCK_DIM_X = 64;
__shared__ float sd[BLOCK_DIM_X];
int stride = gridDim.x * blockDim.x;
float  minval[6];
  int    minind[6];
for (int i = 0; i < 6; ++i)
    minval[i] = 3.402823466e+38F;
for (int i = blockIdx.x * blockDim.x + threadIdx.x; i < c.numvals; i += stride)
    float t = c.in[i];
    int   n = i;
for (int j = 0; j < 6; ++j)
      INSERT_SORTED(j);
for (int k = 1; k != BLOCK_DIM_X; k *= 2)
#if 1
    //BUG!! - this code is the same as below, but this version makes minval and minind arrays get spilled to the local mem!!!
      MERGE_SORTED(i);
#else
    MERGE_SORTED(0);
    MERGE_SORTED(1);
    MERGE_SORTED(2);
    MERGE_SORTED(3);
    MERGE_SORTED(4);
    MERGE_SORTED(5);
#endif
if (threadIdx.x == 0 )
      c.out[blockIdx.x] = make_float2(__int_as_float(minind[i]), minval[i]);
One can specifically request that the compiler unroll a particular loop by using a pragma (see section E.2 of the CUDA C Programming Guide):
for (int k = 1; k != BLOCK_DIM_X; k *= 2) {
#pragma unroll 6
        for (int i = 0; i < 6; ++i) {
            MERGE_SORTED(i);
Thanks for the tip - works like a charm!
