Issue while using SOM of Jetson NANO. we are not able to flash the SOM. Returning error while flashing . I have also attached terminal Image FYR. Kindly advice for further course of action.
is the orin in force recovery mode?
either send reboot command with following : sudo reboot --force forced-recovery options…
or use force_rec pin to set into forced recovery…
as mentioned by @scott104, are you sure the device is in force recovery mode?
What does lsusb
give you?
i have already said :)
When the orin is in device recovery, it is seen by the host, it can be flashed… I flash it already
When you reboot it NOT into force recovery, it is NOT seen by the host.
The flash was good, i can login to the console via UART2 (entering root user and password etc)
