We can now create a new Project CUDA 11.8 by Runtime Visual Studio, but it fails.
This Project can be created as follows:
File => New => Project => Create a new project => CUDA 11.8 Runtime
However, a console application created fails by giving the following error message:
C:\Users\Public\Visual Studio Samples\3 CUDA Apps\CudaRuntime1\x64\Debug\CudaRuntime1.exe (process 11892) exited with code 1.
Although I could write relatively complex C++ We can now create a new Project CUDA 11.8 Runtime, but it fails.
To automatically close the console when debugging stops,
enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
Although I could write relatively complex C++ programs 20 years ago,
C++ hasa changed a lot since then.
As the GitHub samples using CUDA 11.8 and producing graphical output fails
because of OpenGL problem, I am trying to figure out what is causing this problem.
I will appreciate any help.rograms 20 years ago,
C++ has changed a lot since then.
because of OpenGL problem, I am trying to figure out what is causing these problems.
