We have received a nano module and wanted to build.BSP code Can we use nan stock BSP on it and make changes if needed while building from source.
Not a full answer, but some thoughts on this:
- If a carrier board layout differs, then you’ll need to modify the device tree.
- In a command line flash you will find several “
*.conf
” files for the board target. These are human readable scripts, sometimes including files for subcomponents.- If the target example is
jetson-nano-emmc
, then the file used isjetson-nano-emmc.conf
. - Each target file either directly or indirectly is divided into parts for the target module, plus parts related to the target carrier board (e.g., you might see a symbolic link or includes based numeric designations which are designations of particular carrier boards or modules).
- You can easily copy those
.conf
files and make your own custom versions with any edits. - You can log a flash on command line and this tells you where every device tree and image comes from. Example for a dev kit with logging:
sudo ./flash.sh jetson-nano-devkit mmcblk1p1 2>&1 | tee log_flash.txt
(it is the "2>&1 | tee log_flash.txt
" which adds logging) - Most of the rootfs image is from “
Linux_for_Tegra/rootfs/
”, but kernel,extlinux.conf
, and device tree will change based on the flash target. Check the flash log to know what is modified in “/boot
” before creating the flash image. Or “reuse” the image (with the “-r
” option) in “Linux_for_Tegra/bootloader/system.img
” to avoid any modification of “/boot
” content (it’ll use exaclty that image and not create one from “rootfs/
”). - Getting the rootfs the way you want and then cloning is often a good idea. However, you do need to look out for everything being cloned; if you don’t want a user account and password added, then you’d have to remove it in the clone. Similarly if a network rule is based on a MAC address and the MAC is not the same one on different modules.
Expect to use a modified device tree, but everything else will likely be useful without modification. You might want to make other modifications, but most of those are optional.
