We run DeepSeek V4.1 Flash (EXL3, ~2.9-bit) on two NVIDIA GB10 systems, using a customized TensorFold engine with TP2 tensor parallelism over RDMA
Our current setup uses DeepSeek V4.1 Flash with EXL3 quantized weights, served by a customized TensorFold engine across two NVIDIA GB10 systems.
Component Current configuration
Model DeepSeek V4.1 Flash 1017
Weight format EXL3, approximately 2.9 bits per weight
Inference engine Elevatormusic’s TensorFold fork, optimized for V4.1 Flash on dual GB10 systems
Pinned engine commit cb4ceaff2b8c
Deployment One Docker container on each GB10
Model parallelism TP2 tensor parallelism: both systems jointly execute one model
Interconnect ConnectX-7 using RDMA / RoCEv2
Speculative decoding MTP disabled; token-by-token decoding
KV cache 1,048,576-token (1M) dynamically shared pool
Request concurrency 2 concurrent requests, with cache allocated according to demand
Default reasoning Enabled, high effort
Prefill chunk size 1,024 tokens
Image input Enabled; up to 100 images across a request’s full message history
Default sampling temperature=1.0, top_p=1.0
The request flow is:
Client, such as Claude → gateway / compatible API → TensorFold scheduler → joint computation across both GB10 systems → streamed reasoning and final answer.
Input is processed in chunks of 1,024 tokens during prefill, followed by token-by-token generation. Both requests share the same 1M-token cache pool. Input, conversation history, reasoning, and generated answers all consume this capacity. Each request does not receive a separate 1M pool, and the pool is not permanently divided into two 512K partitions.
The API endpoint remains http://192.168.0.166:8000/v1, with the existing model alias DeepSeek-V4.1-Flash-EXL3-2.9bpw. The previous vLLM service is stopped, while its containers, images, weights, and recovery entry point are retained.
Validation completed so far includes default high-effort reasoning, retrieval from a 26K-token input, two concurrent retrieval requests of approximately 128K tokens each, and recognition of nine small images. A full 1M-token request, two simultaneous near-512K requests, 100 large images, and sustained heavy workloads have not yet been validated.
