Dear Jave,
Thank you for your kind comment…
We tried to fix the problem by installing corresponding program as you indicated…
We made the PGDBG on the screen…
But running it with the sample program of WRF which demoed in video teaching, the following error message appeared in MPI message on the screen,
ERROR: MPI Message Queue libray not found.
Try setting :PGDBG_MQS_LIB_OVERRIDE" environment variable
We added the following command in “/etc/csh.cshrc”
setenv PGDBG_MQS_LIB_OVERRIDE /opt/pgi/linux86-64/2012/mpi/mpich/lib/libtvmpich.so.
However we still had the errron message in MPI Messages such as
“ERROR : Process Running”…
Please help me again to fix the problem…
Thank you a lot again…
