We use dp connect to a oled 2560*1600, but after connect it, orin only can bootup with oled lcd
we use dp connect to a oled lcd 2560*1600, but after connect it, orin only can bootup with oled lcd.
  1. boot with the lcd, network can be connected, disconnect the lcd, orin nx power up and can not connect with network
  2. disconnect lcd, and boot up wiht a Display, still not boot up.
hardware connect show :
oled(mipi) <—mipi-2-minidp board <—orin nx miniDP
before connect to the lcd, orin can boot up with Display(>2560 & <2560) or without any display hardware.
Can i modify which file to process this issue?
thansk
看不太懂上面在講什麼. 能否解釋一下display跟LCD分開成兩樣東西在講的差別是什麼?
现状:
用orin nx模块根据参考设计做了一个硬件,通过一个dp转mipi的转换板连接了一个mipi oled屏幕,分辨率是2560*1600.
问题:
  1. 从未连接mipi lcd,仅仅给硬件供电的时候,可以正常启动,可以ssh访问
  2. 连接lcd后,独立硬件供电的时候,系统启动后ssh无法访问,感觉是系统未启动
  3. 不连lcd,直接连接一个pc显示器,一样无法启动,与2的现象相同
這邊要請你了解一下怎麼抓serial console log.
沒有辦法直接從你上面的敘述知道說哪裡造成開機問題
Thanks,
from the serial log we found the root cuase because of a custom program.
