Web Application
Is it possible to install LAMP or Docker Container with Apache, MySQL and PHP on the Xavier NX ( BOXER-8251AI)?
Node.JS and Flask can be options too.
Thanks a lot
We don’t know whether those Web applications can run on ARM64 environment or not, and don’t have experiences with them, may other developers help to provide suggestions. Thanks
Would you be able to install those with apt-get on an Ubuntu desktop Linux PC? If so, try it on the Jetson. Or at least use “apt search mysql” (and similar, just name each package).
Beware, this probably takes significant disk space, so don’t do this unless you know you have sufficient disk space remaining.
