I am trying to setup a SX6036 VPI switch, previously used at another institute. I’ve configured the mgmt interface and can connect to the web UI, however it immediately gives the following error:
Internal Error
An internal error has occurred.
Your options from this point are:
See the logs for more details.
Return to the home page.
Retry the bad page which gave the error.
When I enable logging monitor and try to log in I see the following on the terminal:
Jul 23 11:34:29 ib-switch rh[5127]: [web.ERR]: web_include_template(), web_template.c:364, build 1: can’t use empty string as operand of “!”
Jul 23 11:34:29 ib-switch rh[5127]: [web.ERR]: Error in template “status-logs” at line 545 of the generated TCL code
Jul 23 11:34:29 ib-switch rh[5127]: [web.ERR]: web_render_template(), web_template.c:226, build 1: Error code 14002 (assertion failed) returned
Jul 23 11:34:29 ib-switch rh[5127]: [web.ERR]: main(), rh_main.c:337, build 1: Error code 14002 (assertion failed) returned
Jul 23 11:34:29 ib-switch rh[5127]: [web.ERR]: Request handler failed with error code 14002: assertion failed
Jul 23 11:34:29 ib-switch httpd[4535]: [Mon Jul 23 11:34:29 2018] [error] [client ipremvd] Exited with error code 14002: assertion failed, referer: http://ip.removed./admin/launch?script=rh&template=failure&badpage=%2Fadmin%2Flaunch%3Fscript%3Drh%26template%3Dstatus-logs http://137.158.31.72/admin/launch?script=rh&template=failure&badpage=%2Fadmin%2Flaunch%3Fscript%3Drh%26template%3Dstatus-logs
Any idea as to check what may have failed and how to fix it?
regards
Andrew
