I installed Jetpack before 2 months in my Orin jetson Jetson Nano Super and it i started using it but i can’t open the webcam and in my camera i it has an LED to indicate the camera opens but sometimes it blinks after same time of interval it was an FINGERS 1080 Hi-Res webcam
Do you connect the webcam through USB type-A interface? Would like to confirm which interface is used.
yeah i used a usb Webcam
If you use Orin Nano developer kit, please disconnect the camera and re-connect the camera to USB type-A or type-C port. And check dmesg. See if the camera is correctly enumerated as a highspeed or superspeed device.
It shows as high speed device and then I found the bug in this actually because before I enabled the csi camera dual in it . So can you tell me how to disable the imx219 dual camera ?
We suppose CSI and USB interfaces are independent and should not interfere with each other. A bit strange you see issue after enabling CSI cameras.
If you enable the cameras through jetson-io.py, you can modify extlinux.conf to boot with default device tree. The file is at
/boot/extlinux/extlinux.conf
