Webcam to vp8 encoding dont result in a seekable video
Hello! This string generates a video where it is impossible to choose the position.
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg,format=MJPG,width=1920,height=1080,framerate=60/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! nvv4l2vp8enc bitrate=8000000 ! matroskamux ! filesink location=/home/ances/video.mkv -e
Could someone tell me what I’m doing wrong?
Hi, ances.ai
I have a couple of suggestions:
  • Your pipeline description is incorrect. Do you see any kind of syntax errors? Can you please try (format=MJPG is not valid):
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg,width=1920,height=1080,framerate=60/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! nvv4l2vp8enc bitrate=8000000 ! matroskamux ! filesink location=/home/ances/video.mkv -e
*Also you could try to add jpegparse between v4l2src and the decoder, for example:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg,width=1920,height=1080,framerate=60/1 !  jpegparse ! nvv4l2decoder mjpeg=1 !  nvvidconv ! nvv4l2vp8enc bitrate=8000000 ! matroskamux ! filesink location=/home/ances/video.mkv -e
*Also you could try to simulate your video source and check if the video is seekable, for example:
gst-launch-1.0 videotestsrc is-live=true ! jpegenc ! image/jpeg,format=MJPG,width=1920,height=1080,framerate=60/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! nvv4l2vp8enc bitrate=8000000 ! matroskamux ! filesink location=/home/ances/video.mkv -e
Also can you please share the debug log
GST_DEBUG=2 gst-launch-1.0 -v ...
Jafet Chaves,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Hello jchaves, I have tested your examples. All of them works, but the videos are also unseekable. Thankyou for all your suggestions.
This link have a response pretty interesting.
In a nutshell you need to update the duration metadata at the beginning of the file when you stop the recording.
So, If it is true, I will need to rewrite the video with the right metadata, or use a different codec.
Hi, ances.ai
Just out of curiosity. How are you validating that the video are not seekable?
What does the GStreamer debug say?
Jafet Chaves,
I tried checking the videos with gst-discover. I used this pipeline version to be able to run at 60 fps on a Jetson Nano:
GST_DEBUG=2 gst-launch-1.0 videotestsrc is-live=true num-buffers=600 ! "video/x-raw,format=I420,width=640,height=480,framerate=60/1" !  nvvidconv ! nvjpegenc ! "image/jpeg, width=1920,height=1080,framerate=60/1" ! jpegparse ! nvv4l2decoder mjpeg=1 ! nvvidconv ! nvv4l2vp8enc ! matroskamux ! filesink location=video.mkv -e
This is the output of gst-discover
Analyzing file:///home/user/video.mkv
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 278
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 278
Done discovering file:///home/user/video.mkv
Topology:
  container: Matroska
    video: VP8
Properties:
  Duration: 0:00:09.999999600
  Seekable: yes
  Live: no
  Tags:
      container format: Matroska
      video codec: On2 VP8
I also checked the videos with VLC and I can drag the progress bar to different places and the video would just pick up from there without issues.
Can you please check the videos with gst-discover and a video player (like vlc) too?
Jafet Chaves,
Hi!
This is a debug output:
Setting pipeline to PAUSED …
0:00:00.414678995 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8970790 Failed to determine interlace mode
0:00:00.414771237 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8970790 Failed to determine interlace mode
0:00:00.414831551 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8970790 Failed to determine interlace mode
0:00:00.414893583 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8970790 Failed to determine interlace mode
0:00:00.415006867 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:4476:gst_v4l2_object_probe_caps:nvv4l2vp8enc0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.461098145 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:4476:gst_v4l2_object_probe_caps:nvv4l2decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.461186949 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8968390 Failed to determine interlace mode
0:00:00.461241638 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8968390 Failed to determine interlace mode
0:00:00.461300858 20868 0x55b8986f80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8968390 Failed to determine interlace mode
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
NvMMLiteOpen : Block : BlockType = 277
NvMMLiteBlockCreate : Block : BlockType = 277
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.523397473 20868 0x55b895df70 WARN v4l2bufferpool gstv4l2bufferpool.c:790:gst_v4l2_buffer_pool_start:v4l2src0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:01.039598884 20868 0x55b895df70 WARN v4l2 gstv4l2object.c:4476:gst_v4l2_object_probe_caps:nvv4l2decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:01.039655760 20868 0x55b895df70 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8968390 Failed to determine interlace mode
0:00:01.039695240 20868 0x55b895df70 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8968390 Failed to determine interlace mode
0:00:01.039729512 20868 0x55b895df70 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55b8968390 Failed to determine interlace mode
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)Y42B, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, format=(string)I420, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/nvv4l2vp8enc:nvv4l2vp8enc0.GstPad:src: caps = video/x-vp8, profile=(string)0, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstMatroskaMux:matroskamux0.GstMatroskamuxPad:video_0: caps = video/x-vp8, profile=(string)0, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
Redistribute latency…
NvMMLiteOpen : Block : BlockType = 7
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 7
0:00:01.045949976 20868 0x55b895df70 WARN v4l2bufferpool gstv4l2bufferpool.c:1087:gst_v4l2_buffer_pool_start:nvv4l2vp8enc0:pool:src Uncertain or not enough buffers, enabling copy threshold
/GstPipeline:pipeline0/nvv4l2vp8enc:nvv4l2vp8enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, format=(string)I420, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)Y42B, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1
0:00:01.046790882 20868 0x55b895df70 WARN v4l2videodec gstv4l2videodec.c:1755:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:01.054387316 20868 0x55b895df70 WARN v4l2bufferpool gstv4l2bufferpool.c:1087:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:01.063559935 20868 0x7fa00030f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1536:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:01.077859919 20868 0x55b895df70 WARN v4l2src gstv4l2src.c:976:gst_v4l2src_create: lost frames detected: count = 4 - ts: 0:00:00.593911882
NVMEDIA_ENC: bBlitMode is set to TRUE
0:00:01.111628396 20868 0x7fa0003a80 WARN v4l2bufferpool gstv4l2bufferpool.c:1536:gst_v4l2_buffer_pool_dqbuf:nvv4l2vp8enc0:pool:src Driver should never set v4l2_buffer.field to ANY
/GstPipeline:pipeline0/GstMatroskaMux:matroskamux0.GstPad:src: caps = video/x-matroska
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-matroska
/GstPipeline:pipeline0/GstMatroskaMux:matroskamux0.GstPad:src: caps = video/x-matroska, streamheader=(buffer)< 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 >
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-matroska, streamheader=(buffer)< 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 >
^Chandling interrupt.
Interrupt: Stopping pipeline …
EOS on shutdown enabled – Forcing EOS on the pipeline
Waiting for EOS…
0:00:05.988176159 20868 0x7fa0003a80 WARN v4l2allocator gstv4l2allocator.c:1505:gst_v4l2_allocator_dqbuf:nvv4l2vp8enc0:pool:src:allocator V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:00:05.525393963
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
With a buch of players (windows player, MPV, VLC), and certainly, only VLC allow to seek the video.
I don’t see anything out of the ordinary based on the GST_DEBUG log that you provided. Did you try to check the output of gst-discover?
Also I am wondering the different results with other media players. I wonder if the decoding backend (FFmpeg for example) could cause this.
