Yes, of course I tried it. It has executable permission even with chmod 777 it won’t work, and neither using shabang. Is it working for you when you test it? @dusty_nv
Hi @dusty_nv
following line by line your exact process, it worked on normal shell (ext4) on Orin AGX, but not in a docker container from NGC. (Even I’m executing atest from /bin/bash shell)
@dusty_nv I thought it had something to do with running out of space in the docker container, but I tested it (‘docker cp’ worked after I freed some space) and that wasn’t the case. in my case, what I narrowed down so far, bash atest works bash ./atest works ./atest seems to work on the local disk (such as /tmp) but not on the external disk where docker is
so I worked around this for now by moving the executing script to the local disk
Create a file in the same manner which fails, but add only this command after the shebang: which bash
Also, on command line (not in the script), run:
ls -l `which bash`
(compare to the shebang)
It seems likely that the docker environment is lacking access to something. Sometimes the shell itself is incorrect as there will sometimes be two versions of bash: One for restricted access used by system accounts, and another used by normal end users. Along with that there may be things linked in which also change. The behavior of a script can depend on the name used for accessing the script, e.g., there is an argument presented to the program which would respond differently if the program is accessed directly, versus if the program is accessed through a symbolic link alias. That difference might be in some function called and not the bash script itself.
