Please help me, I don’t know what I’m doing wrong.
I’m using the MACRO HANDLE_ERROR to check where my program is not working and it seems that some of the cudaMemcpy calls are not working 'cuz I’m getting this error:
“unspecified launch failure in X.cu at line 198”
and that line is :
HANDLE_ERROR( cudaMemcpy( id, dev_id, sizeof(int), cudaMemcpyDeviceToHost ) );
the weird part is that I’ve already reserve memory for both id and dev_id before that cudaMemcpy call here is a part of my code:
int id;
id = (int)malloc(sizeof(int));
HANDLE_ERROR( cudaMalloc( (void**)&dev_id, sizeof(int) ) );
recognize<<<blocks,threads>>>(dev_red, dev_redVec, dev_cmp, dev_con, dev_ptr, dev_id);
HANDLE_ERROR( cudaMemcpy( MRED, dev_red, *tamRed * sizeof(int), cudaMemcpyDeviceToHost ) );
HANDLE_ERROR( cudaMemcpy( MREDvec, dev_redVec, *tamRedV * sizeof(int), cudaMemcpyDeviceToHost ) );
I’m getting the same error in the other two calls of cudaMemcpy.
