Hello ,
I have this problem.When I am running the code through terminal ,it gives me sometimes another value for my result.
In the nsight debugger I am not receving any errors (except when running the code at some part it shows
warning: Unmapped DWARF Register #83886081 encountered.
cuda-gdb/7.2/gdb/regcache.c:181: internal-error: register_size: Assertion `regnum >= 0 && regnum < (gdbarch_num_regs (gdbarch) + gdbarch_num_pseudo_regs (gdbarch))' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) [answered Y; input not from terminal]
Create a core file of GDB? (y or n) [answered Y; input not from terminal]
but the code executes just fine!
If I run cuda-memcheck from terminal it shows me 30 errors:
Program hit error 29 on CUDA API call to cudaFree
Program hit error 29 on CUDA API call to cudaEventDestroy
Program hit error 29 on CUDA API call to cudaThreadSynchronize
Any ideas??
