• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 8.6.2
I was trying to read a rtsp stream byt using this pipeline and was getting this message
After uninstalling gstreamer1.0-pluglins-ugly, I was able to read the stream.
Why does that happen?Are there any workarounds?
this was the command I was using to test it
GST_DEBUG=3 gst-launch-1.0 uridecodebin uri="<my-url-link>" ! fakevideosink
case GST_RESOURCE_ERROR_READ:
return _("Could not read from resource.");
This is caused by the server not responding, not a issue with gstreamer or deepstream.
The following command line works fine
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! fakevideosink
The thing is I had to remove the lib for it to work on Jetson. I didn’t have to remove it for it to work on my notebook. I wonder what might be causing this. So far I am managing to work without the plugins provided by gstreamer1.0-pluglins-ugly. Not sure if it is some weird interaction with the camera. I just hope to fix it so I can use these extra plugins if I need them in the future.
This is indeed a strange problem. I don’t know the reason and can’t reproduce it on my AGX Orin.
Please use the following command to dump the log after installing the gstreamer1.0-pluglins-ugly.
GST_DEBUG_NO_COLOR=1 GST_DEBUG=7 gst-launch-1.0 uridecodebin uri=xxx ! fakevideosink > log.log 2>&1
Or try the following command to reinstall the dependencies
apt-get update
apt-get install -y gstreamer1.0-libav
# ubuntu 22.04
apt-get install --reinstall -y gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly libswresample-dev libavutil-dev libavutil56 libavcodec-dev libavcodec58 libavformat-dev libavformat58 libavfilter7 libde265-dev libde265-0 libx265-199 libx264-163 libvpx7 libmpeg2encpp-2.1-0 libmpeg2-4 libmpg123-0
yingliu
December 30, 2024, 10:25am
6
system
Closed
January 13, 2025, 10:25am
7
