weird (incorrect) compiler output - very minor issue
I have a subroutine with the following code in it. The DO WHILE is at line 134.
DO WHILE ( loop_on )
! BEGIN LOOP
! SOLVE THE EQUATIONS
DO j = 1, nelem
w(j) = ZERO
wtemp(j) = ZERO
sig_j(j) = ZERO
DO i = 1, nfmaxp2
IF ( CN(i,j)>0 ) wtemp(j) = wtemp(j) + A(i,j)*p(CN(i,j))
ENDDO
w(j) = (wtemp(j)+B(j)p(j))/B(j)
sig_j(j) = q(j)w(j)
ENDDO
sig = ZERO
! OVERRELAXED JACOBI CGS
DO j = 1, nelem
sig = sig + sig_j(j)
ENDDO
IF ( sig==ZERO ) sig = tol
alpha = rho/sig
DO j = 1, nelem
h(j) = u(j) - alpha
w(j)
u(j) = (u(j)+h(j))alpha
Tn(j) = Tn(j) + u(j)
ENDDO
DO j = 1, nelem
w(j) = ZERO
rho_j(j) = ZERO
DO i = 1, nfmaxp2
IF ( CN(i,j)>0 ) w(j) = w(j) + A(i,j)u(CN(i,j))
ENDDO
w(j) = (w(j)+B(j)u(j))/B(j)
r(j) = r(j) - w(j)
rho_j(j) = q(j)r(j)
ENDDO
rsum = ZERO
nindex = 0
rho1 = rho
IF ( rho1==ZERO ) rho1 = tol
rho = ZERO
DO j = 1, nelem
sumold = rsum
rsum = MAX(rsum,ABS(u(j)/Tn(j)))
IF ( rsum/=sumold ) nindex = j
rho = rho + rho_j(j)
ENDDO
beta = rho/rho1
DO j = 1, nelem
u(j) = r(j) + beta
h(j)
p(j) = u(j) + beta
(beta
p(j)+h(j))
ENDDO
IF ( rsum<tol ) loop_on = .FALSE.
iter = iter + 1
IF ( iter>1000 ) THEN
WRITE (6,
) ’ Too Many Iterations in CGS’
WRITE (6,
) ’ ABORTING…’
STOP
ENDIF
IF ( itero==1 ) first_cycle2 = .FALSE.
ENDDO
Output from 13.3 compiler for this outer loop is
" 134, Loop not vectorized/parallelized: contains call".
Now I actually didn’t expect the compiler to vectorized or parallelize this loop but the reason given (“contains call”) is wrong .
-ralph
Hi Ralph,
It’s probably the WRITE and/or STOP statement, which are calls. MAX and ABS are calls as well, but usually get inlined at higher optimization levels so shouldn’t cause this message.
What happens if you comment out:
WRITE (6,*) ' Too Many Iterations in CGS'
WRITE (6,*) ' ABORTING...'
STOP
ENDIF
  • Mat
A little clarification in the compiler output could help, e.g.
" 134, Loop not vectorized/parallelized: contains call, e.gl write, stop, subrountine, etc."
Plus I’m using the highest level of optimization you have. I’ll test commenting out the write statement.
