All,
Recently, we’ve tried to re-up our PGI support for the model I work on, working on trying to fix/workaround F2003/2008 features we use that PGI doesn’t quite support yet. However, in doing so we encountered a rather odd bug. We eventually figured out that the column a pre-processor macro starts in, can sometimes cause an issue.
To wit, I present a stripped down code that has a waterfall of _ASSERT():
# define __return return
# define __rc(rc) ,rc
#define _FILE_ __FILE__
# define _ASSERT_MSG_AND_LOC_AND_RC(A,msg,file,line,rc) if(MAPL_Assert(A,msg,file,line __rc(rc)))__return
# define _ASSERT_MSG_AND_LOC(A,msg,file,line) _ASSERT_MSG_AND_LOC_AND_RC(A,msg,file,line,rc)
# define _ASSERT(A,msg) _ASSERT_MSG_AND_LOC(A,msg,_FILE_,__LINE__)
subroutine MAPL_FieldAllocCommit(rc)
_ASSERT(.false.,"column=1")
_ASSERT(.false.,"column=2")
_ASSERT(.false.,"column=3")
_ASSERT(.false.,"column=4")
_ASSERT(.false.,"column=5")
_ASSERT(.false.,"column=6")
_ASSERT(.false.,"column=7")
_ASSERT(.false.,"column=8")
_ASSERT(.false.,"column=9")
_ASSERT(.false.,"column=10")
_ASSERT(.false.,"column=11")
_ASSERT(.false.,"column=12")
_ASSERT(.false.,"column=13")
_ASSERT(.false.,"column=14")
_ASSERT(.false.,"column=15")
_ASSERT(.false.,"column=16")
_ASSERT(.false.,"column=17")
_ASSERT(.false.,"column=18")
_ASSERT(.false.,"column=19")
_ASSERT(.false.,"column=20")
_ASSERT(.false.,"column=21")
_ASSERT(.false.,"column=22")
_ASSERT(.false.,"column=23")
_ASSERT(.false.,"column=24")
_ASSERT(.false.,"column=25")
_ASSERT(.false.,"column=26")
_ASSERT(.false.,"column=27")
end subroutine MAPL_FieldAllocCommit
If you now run this through pgfortran:
(1054) $ pgfortran -V
pgfortran 19.10-0 LLVM 64-bit target on x86-64 Linux -tp skylake
PGI Compilers and Tools
Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
(1055) $ pgfortran test.F90 -E
# 1 "test.F90"
# 11 "test.F90"
if(MAPL_Assert(.false.,"column=1","test.F90",12 ,rc))return
if(MAPL_Assert(.false.,"column=2","test.F90",13 ,rc))return
if(MAPL_Assert(.false.,"column=3","test.F90",14 ,rc))return
if(MAPL_Assert(.false.,"column=4","test.F90",15 ,rc))return
if(MAPL_Assert(.false.,"column=5","test.F90",16 ,rc))return
if(MAPL_Assert(.false.,"column=6","test.F90",17 ,rc))return
if(MAPL_Assert(.false.,"column=7","test.F90",18 ,rc))return
if(MAPL_Assert(.false.,"column=8","test.F90",19 ,rc))return
if(MAPL_Assert(.false.,"column=9","test.F90",20 ,rc))return
if(MAPL_Assert(.false.,"column=10","test.F90",21 ,rc))return
if(MAPL_Assert(.false.,"column=11","test.F90",22 ,rc))return
if(MAPL_Assert(.false.,"column=12","test.F90",23 ,rc))return
if(MAPL_Assert(.false.,"column=13","test.F90",24 ,rc))return
if(MAPL_Assert(.false.,"column=14","test.F90",25 ,rc))return
C(.false.,"column=15","test.F90",26)
if(MAPL_Assert(.false.,"column=16","test.F90",27 ,rc))return
if(MAPL_Assert(.false.,"column=17","test.F90",28 ,rc))return
C(.false.,"column=18","test.F90",29,rc)
if(MAPL_Assert(.false.,"column=19","test.F90",30 ,rc))return
if(MAPL_Assert(.false.,"column=20","test.F90",31 ,rc))return
if(MAPL_Assert(.false.,"column=21","test.F90",32 ,rc))return
if(MAPL_Assert(.false.,"column=22","test.F90",33 ,rc))return
if(MAPL_Assert(.false.,"column=23","test.F90",34 ,rc))return
if(MAPL_Assert(.false.,"column=24","test.F90",35 ,rc))return
if(MAPL_Assert(.false.,"column=25","test.F90",36 ,rc))return
if(MAPL_Assert(.false.,"column=26","test.F90",37 ,rc))return
if(MAPL_Assert(.false.,"column=27","test.F90",38 ,rc))return
So if our macro starts in column 15 or 18, it doesn’t resolve correctly. You can see that _ASSERT() is a rather complex, nested macro but not horrible. Intel and GNU (and thus cpp) seem okay with this macro.
Now, I fiddled around and if you run with
pgfortran test.F90 -Mcpp=line -E
you don’t get the above issue. But since I don’t think you can use -Mcpp in combination with compilation, doesn’t really help us.
Any ideas?
