global void emptyKernel()
global void testKernel()
int i = 0;
int j = 2;
i+=j;
Why do the two kernels above produce the same number of registers used - 2?
What registers does an empty kernel use? Are they the threadIdx and blockIdx?
The second kernel generates 2 registers also. Is it because i and j are eliminated in optimization? Where does the optimization take place? The generation of PTX or machine code?
Is there a way that would allow me to view/edit PTX code?
int i = 0;
int j = 2;
i+=j;
If you’re using nvcc compiler, try “–keep” option to keep all the temporary files, including PTX.
About registers, my nvcc uses 1 register for a kernel calculating only 1000000 sines in a cycle. Empty kernel uses no registers.
Hey umod, I’m using toolkit version 3.2 on GF104. What’s your version? How did you get the register count? By visual profiler too?
Is this a problem with the visual profiler? Here’s the PTX code generated from emptyKernel
.entry _Z11emptyKernelv
.loc 16 17 0
$LDWbegin__Z11emptyKernelv:
.loc 16 20 0
exit;
$LDWend__Z11emptyKernelv:
} // _Z11emptyKernelv
Here’s the machine code generated in the cubin
00000000: 2800440400005de4 mov b32 $r1 c1[0x100]
00000008: 8000000000001de7 exit
I could only see 1 register, which is $r1. What is c1 there?
.loc 16 17 0
.loc 16 20 0
exit;
I’m working under Linux with latest toolkit and drivers (3.2 and 260.19.21). I use “nvcc --ptxas-options=-v
ptxas info : Compiling entry function '_Z4noopPi'
ptxas info : Used 2 registers, 8+16 bytes smem
Kernel looks like this:
__global__ void noop(int *a)
a[threadIdx.x]=threadIdx.x;
c1 and c2 are constant memory spaces
