What are mode_type/pixel_phase of monochrome sensors?
Dear forum,
I am bringing up the monochrome version of the Sony IMX296 senor. Its color version has following properties :
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
mode_type = "bayer";
pixel_phase = "rggb";
I would like to know what will be the correct mode_type and pixel_phase for the monochrome version, please ?
And are monochrome sensors supported by default or should I add the support for them into the official BSP? I am using Jetpack-5.1.2
Best Regards,
Khang
Best Regards,
Khang
The mode_type is correct if it’s Bayer sensor.
For the pixel_phase may need to adjust by checking the sensor out.
And need add below.
Hi @ShaneCCC,
This is where I am still confused: the color version is surely RAW10 Bayer. But for the monochrome version, it is only RAW10.
I found the following example and think that it is a good one : vc_mipi_nvidia/patch/kernel_Xavier_35.4.1+/0001-Added-RAW8-grey-RAW10-y10-RAW12-y12-and-RAW14-y14-fo.patch at master · VC-MIPI-modules/vc_mipi_nvidia · GitHub
Best Regards,
Khang
Hi @ShaneCCC,
By the way talking about the monochrome sensors, there’s an instruction from Vision-Components repository’s README saying that :
As far as I know, OV9281 is also a monochrome sensor but it seems that in order to use gstreamer with nvarguscamerasrc, one has to let its pixel_t to RG8 or RG10. The pixel_t is deprecated and replaced by mode_type, csi_pixel_bit_depth and pixel_phase according to the Sensor Software Driver Programing R35.4.1. So I deduce that I should let them as in the initial comment for being able to use my IMX296LLR monochrome with nvarguscamerasrc.
BTW, 8bit don’t support. Current nvarguscamerasrc support 10/12/14 bits only.
Hi @ShaneCCC,
Thanks for the useful information. I will also have the need to bringup the ov9281 for myself as well.
