I trained resnet-10 classification model on my own dateset, and has 2 classes.
Q1: Doing inference the trained model with tlt evaluation and enable-center-crop=True, I get high accuracy, and I want to know how I can set enable-center-crop=True in the config file? Is it necessary? I test the trained model with tlt evaluation with enable-center-crop=False, I get worse results.
Q2: In the config file, there are net-scale-factor, offset and model-color-format, What are these values?
Q3- The input size of model is 224x224x3, Is it necessary to resize all of images to 244x224x3 before training?
@Fiona.Chen,
I know offset is the means of each RGB channels, But in practical, because I used fine-tune on my own dataset, The values of offset mode should to be in documentation or config training, I don’t know I have to calculate offset values for my own dataset?
