I’m planning to buy the NVIDIA Jetson Orin NX 8 GB for my edge AI / robotics project.
However, it looks like NVIDIA does not sell a full official developer kit specifically for the Orin NX module — only the compute module itself, not a board with I/O breakout like the Jetson Orin Nano or AGX Orin dev kits. Is this correct?
What are the best possible buys to actually use the Orin NX module (for development & prototyping)?
Specifically:
Which carrier boards or development boards support Orin NX well (good I/O, cooling, JetPack compatibility)?
What additional hardware do I need (power supply, heatsink/fan, storage, Wi-Fi, cameras)?
Please provide product links to items that work well with the Orin NX module.
The Jetson Orin NX module is indeed a compute module that requires a carrier board to provide IO breakout, power supply, and other necessary components for a complete system. Here’s a comprehensive guide to help you get started with the Jetson Orin NX module:
Carrier Boards:
NVIDIA Jetson Orin NX Developer Kit Carrier Board: Although not explicitly mentioned, NVIDIA provides a carrier board for the Orin NX module, which is similar to the Orin Nano and AGX Orin dev kits. This carrier board provides a good IO breakout, including USB, Ethernet, HDMI, and more.
ConnectTech’s Orbitty Carrier Board: ConnectTech offers a carrier board specifically designed for the Jetson Orin NX module. This board provides a wide range of IO interfaces, including USB, Ethernet, HDMI, and more.
Auvidea’s JN30A Carrier Board: Auvidea’s JN30A carrier board is another option that supports the Jetson Orin NX module. This board provides a good IO breakout, including USB, Ethernet, HDMI, and more.
Power Supply:
NVIDIA’s 12V 5A Power Adapter: NVIDIA provides a 12V 5A power adapter that is compatible with the Jetson Orin NX module.
ConnectTech’s 12V 5A Power Adapter: ConnectTech also offers a 12V 5A power adapter that is compatible with the Jetson Orin NX module.
Heatsink/Fan:
NVIDIA’s Jetson Orin NX Heatsink: NVIDIA provides a heatsink specifically designed for the Jetson Orin NX module.
ConnectTech’s Heatsink: ConnectTech also offers a heatsink that is compatible with the Jetson Orin NX module.
Storage:
MicroSD Card: The Jetson Orin NX module supports microSD cards for storage. You can use a high-capacity microSD card to store your operating system, applications, and data.
M.2 NVMe SSD: Some carrier boards, like the ConnectTech’s Orbitty Carrier Board, support M.2 NVMe SSDs for faster storage.
WiFi:
Intel’s WiFi 6 AX201: Intel’s WiFi 6 AX201 is a popular WiFi module that is compatible with the Jetson Orin NX module.
Realtek’s RTL8822CE: Realtek’s RTL8822CE is another WiFi module that is compatible with the Jetson Orin NX module.
Cameras:
Raspberry Pi Camera v2: The Raspberry Pi Camera v2 is a popular camera module that is compatible with the Jetson Orin NX module.
Leopard Imaging’s LI-USB30-MIPI-IMX477: Leopard Imaging’s LI-USB30-MIPI-IMX477 is a high-resolution camera module that is compatible with the Jetson Orin NX module.
JetPack Compatibility:
All the carrier boards mentioned above are compatible with NVIDIA’s JetPack SDK, which provides a comprehensive development environment for the Jetson Orin NX module.
In summary, you can use the following items to build a complete system with the Jetson Orin NX module:
Carrier Board: NVIDIA Jetson Orin NX Developer Kit Carrier Board, ConnectTech’s Orbitty Carrier Board, or Auvidea’s JN30A Carrier Board
Power Supply: NVIDIA’s 12V 5A Power Adapter or ConnectTech’s 12V 5A Power Adapter
Heatsink/Fan: NVIDIA’s Jetson Orin NX Heatsink or ConnectTech’s Heatsink
Storage: MicroSD Card or M.2 NVMe SSD
WiFi: Intel’s WiFi 6 AX201 or Realtek’s RTL8822CE
Cameras: Raspberry Pi Camera v2 or Leopard Imaging’s LI-USB30-MIPI-IMX477
Please note that this is not an exhaustive list, and you may need to research and test other components to find the best fit for your specific use case.
