I have been using the Nova Carter because it worked seamlessly with ROS2 (thank you to the developer team)! Now I want to use a quadruped platform, but I’m having trouble figuring out how to enable the platform to use ROS2 in IsaacSim.
I understand that using an Omnigraph to build out the ROS2 structure might be the way, but how would that translate to the low level joint control of a quadruped? Could someone provide an outline of the steps needed to make a Quad platform work with ROS2?
