Is it CPU-synchronous or not? Does it stall the GPU execution stream mid-run because the CPU can’t queue more work on the stream until after preceding GPU work on the acquired frame has completed?
It takes a CUstream, so you’d think it worked asynchronously. But, it returns the frame synchronously and then you pass that frame to cuGraphicsResourceGetMappedEglFrame definitely works synchronously. And, you can’t queue a kernel to consume the frame until after you have it’s address.
I’m not asking about the timeout parameter.
Does the function synchronize the GPU with the CPU?
For example:
cuEGLStreamConsumerAcquireFrame(&conn_, &resource, &stream_, timeout);
// Do we need to call cuStreamSynchronize(stream_) here?
cuGraphicsResourceGetMappedEglFrame(&eglFrame, resource, 0, 0);
cuEGLStreamConsumerReleaseFrame(&conn_, resource, &stream_);
@AastaLLL
This function maps the pinned CPU buffer into EGL driver.
Since it is a zero-copy mechanism, there is no GPU computation.
You don’t need to call the cuStreamSynchronize
in the case above.
Instead, please validate if cuEGLStreamConsumerAcquireFrame
return success.
