I found that model-color-format should be “0” for RGB and “1” for BGR configuration. I also found that the Segmentation configuration file “dstest_segmentation_config_industrial.txt” contain “model-color-format = 2”. Could you provide more details please? What this “2” option mean?
Documentation: https://docs.nvidia.com/metropolis/deepstream/4.0/DeepStream_Plugin_Manual.pdf
Thank you,
Ondra
In gstnvinfer_property_parser.cpp
} else if (!g_strcmp0 (*key, CONFIG_GROUP_INFER_MODEL_COLOR_FORMAT)) {
guint val = g_key_file_get_integer (key_file, CONFIG_GROUP_PROPERTY,
CONFIG_GROUP_INFER_MODEL_COLOR_FORMAT, &error);
CHECK_ERROR (error);
switch (val) {
case 0:
nvinfer->init_params->networkInputFormat = NvDsInferFormat_RGB;
break;
case 1:
nvinfer->init_params->networkInputFormat = NvDsInferFormat_BGR;
break;
case 2:
nvinfer->init_params->networkInputFormat = <b>NvDsInferFormat_GRAY</b>;
break;
default:
g_printerr ("Error. Invalid value for '%s':'%d'\n",
CONFIG_GROUP_INFER_MODEL_COLOR_FORMAT, val);
goto done;
break;
nvdsinfer_context.h
* Enum for color formats.
typedef enum
/** 24-bit interleaved R-G-B */
NvDsInferFormat_RGB,
/** 24-bit interleaved B-G-R */
NvDsInferFormat_BGR,
/** 8-bit Luma */
NvDsInferFormat_GRAY,
/** 32-bit interleaved R-G-B-A */
NvDsInferFormat_RGBA,
/** 32-bit interleaved B-G-R-x */
NvDsInferFormat_BGRx,
NvDsInferFormat_Unknown = 0xFFFFFFFF,
} NvDsInferFormat;
nvinfer supports not only rgb/bgr, but also gray format.
