What badge should I use for 8 or more camera system?
Hello there,
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html?highlight=media0#module-properties
The guide for camera driver implementations only mentions values for the “position” property in the device tree up to six cameras, what names should be used for a system with more than 6 cameras (8, 12, 16)?
hello TobidieTopfplanze,
for the use-case with more than 6 cameras, you may choosing the position property with hex values.
Thanks for the quick reply!
Provided as number or string? (“0x02” or <0x02>)
that should be all okay, since there’s update to make sensor placement error harmless.
you may see-also Topic 184902, please take the values from 0 to F to assign the positions property.
