What could cause example code oclMatVecMul to produce wrong results? "GPU Result DOESN'T MAT
Hi everybody,
I tried today another example from the sdk, oclMatVecMul, but I get following error message: “GPU Result DOESN’T MATCH CPU Result within allowable tolerance”
oclMatrixMul on the other hand works. What could cause this behavior?
Thanks in advance!
I did further research and it looks like it depends on the dimensions of matrix, but not on the size, i.e. the bigger one works, the smaller one doesn’t. Do you have an idea, what could be the cause of this?
I attached the results of two different runs. The first one passes with the dimensions of 2525 * 13271 * 4 = 134037100. The second one fails with Matrix width 5050 * 6635 *4 = 134027000. Where 134037100 - 134027000 = 10100 = 4 * 2525.
Determining Matrix height from available GPU mem...
 oclGetPlatformID...
 clGetDeviceIDs clCreateContext...
 clGetDeviceInfo...
 Matrix width	= 2525
 Matrix height	= 13271
Allocate and Init Host Mem...
Get the Platform ID...
Get the Device info and select Device...
 # of Devices Available = 1
 Using Device 0: Quadro FX 580
 # of Compute Units = 4
clCreateContext...
clCreateCommandQueue...
clCreateBuffer (M, V and W in device global memory, mem_size_m = 134037100)...
oclLoadProgSource (oclMatVecMul.cl)...
clCreateProgramWithSource...
clBuildProgram...
clEnqueueWriteBuffer (M and V)...
Running with Kernel MatVecMulUncoalesced0...
Clear result with clEnqueueWriteBuffer (W)...
  clCreateKernel...
  Global Work Size 		= 13312
  Local Work Size 		= 256
  # of Work Groups 		= 52
  clSetKernelArg...
clEnqueueNDRangeKernel (MatVecMulUncoalesced0)...
  clEnqueueReadBuffer (W)...
  Comparing against Host/C++ computation...
GPU Result MATCHES CPU Result within allowable tolerance
Running with Kernel MatVecMulUncoalesced1...
  clCreateKernel...
  Global Work Size 		= 2048
  # of Work Groups 		= 8
  clSetKernelArg...
clEnqueueNDRangeKernel (MatVecMulUncoalesced1)...
Running with Kernel MatVecMulCoalesced0...
  clCreateKernel...
  clSetKernelArg...
clEnqueueNDRangeKernel (MatVecMulCoalesced0)...
Running with Kernel MatVecMulCoalesced1...
  clCreateKernel...
  clSetKernelArg...
clEnqueueNDRangeKernel (MatVecMulCoalesced1)...
Running with Kernel MatVecMulCoalesced2...
  clCreateKernel...
  clSetKernelArg...
clEnqueueNDRangeKernel (MatVecMulCoalesced2)...
Running with Kernel MatVecMulCoalesced3...
  clCreateKernel...
  clSetKernelArg...
clEnqueueNDRangeKernel (MatVecMulCoalesced3)...
PASSED
Starting Cleanup...
oclMatVecMul.exe Exiting...
Press <Enter> to Quit
 oclGetPlatformID...
 clGetDeviceInfo...
 Matrix width	= 5050
 Matrix height	= 6635
clCreateContext...
clCreateBuffer (M, V and W in device global memory, mem_size_m = 134027000)...
clBuildProgram...
  clCreateKernel...
  Global Work Size 		= 6656
  # of Work Groups 		= 26
  clSetKernelArg...
GPU Result DOESN'T MATCH CPU Result within allowable tolerance
  clCreateKernel...
  clSetKernelArg...
  clCreateKernel...
  clSetKernelArg...
  clCreateKernel...
  clSetKernelArg...
  clCreateKernel...
  clSetKernelArg...
  clCreateKernel...
  clSetKernelArg...
FAILED
Starting Cleanup...
Further testing, I found that in some cases the Kernel returns in 0s with “0” values. Any idea?
./oclMatrixMul Starting...
Using Matrix Sizes: A(8000 x 16000), B(8000 x 8000), C(8000 x 16000)
Running Computations on 1 - 1 GPU's...
oclMatrixMul, Throughput = 30906456.9153 GFlops/s, Time = 0.00007 s, Size = 2048000000000, NumDevsUsed = 1, Workgroup = 256
Kernel execution time on GPU 0 	: 0.00000 s
Comparing results with CPU computation...
Listing first 100 Differences > 0.000010...
Row 0:
    Loc(0,0)	CPU=1992.44897	GPU=0.00000	Diff=1992.448975
    Loc(1,0)	CPU=1992.28149	GPU=0.00000	Diff=1992.281494
    Loc(2,0)	CPU=2000.21448	GPU=0.00000	Diff=2000.214478
    Loc(3,0)	CPU=2008.32019	GPU=0.00000	Diff=2008.320190
    Loc(4,0)	CPU=1998.52942	GPU=0.00000	Diff=1998.529419
    Loc(5,0)	CPU=2017.58997	GPU=0.00000	Diff=2017.589966
    Loc(6,0)	CPU=1992.80225	GPU=0.00000	Diff=1992.802246
    Loc(7,0)	CPU=2004.28503	GPU=0.00000	Diff=2004.285034
    Loc(8,0)	CPU=2000.10669	GPU=0.00000	Diff=2000.106689
    Loc(9,0)	CPU=1997.23682	GPU=0.00000	Diff=1997.236816
    Loc(10,0)	CPU=1985.83606	GPU=0.00000	Diff=1985.836060
    Loc(11,0)	CPU=2007.43274	GPU=0.00000	Diff=2007.432739
    Loc(12,0)	CPU=1992.11462	GPU=0.00000	Diff=1992.114624
    Loc(13,0)	CPU=1995.93408	GPU=0.00000	Diff=1995.934082
    Loc(14,0)	CPU=1990.54260	GPU=0.00000	Diff=1990.542603
    Loc(15,0)	CPU=1996.68384	GPU=0.00000	Diff=1996.683838
    Loc(16,0)	CPU=1988.17065	GPU=0.00000	Diff=1988.170654
    Loc(17,0)	CPU=2012.80896	GPU=0.00000	Diff=2012.808960
    Loc(18,0)	CPU=2015.77893	GPU=0.00000	Diff=2015.778931
    Loc(19,0)	CPU=2027.57263	GPU=0.00000	Diff=2027.572632
    Loc(20,0)	CPU=2013.63623	GPU=0.00000	Diff=2013.636230
    Loc(21,0)	CPU=2034.78210	GPU=0.00000	Diff=2034.782104
    Loc(22,0)	CPU=1997.21558	GPU=0.00000	Diff=1997.215576
    Loc(23,0)	CPU=2045.86340	GPU=0.00000	Diff=2045.863403
    Loc(24,0)	CPU=2027.31152	GPU=0.00000	Diff=2027.311523
    Loc(25,0)	CPU=1984.99695	GPU=0.00000	Diff=1984.996948
    Loc(26,0)	CPU=1996.16833	GPU=0.00000	Diff=1996.168335
    Loc(27,0)	CPU=1993.75476	GPU=0.00000	Diff=1993.754761
    Loc(28,0)	CPU=2004.76868	GPU=0.00000	Diff=2004.768677
    Loc(29,0)	CPU=2007.93701	GPU=0.00000	Diff=2007.937012
    Loc(30,0)	CPU=2030.28711	GPU=0.00000	Diff=2030.287109
    Loc(31,0)	CPU=2027.95984	GPU=0.00000	Diff=2027.959839
    Loc(32,0)	CPU=2003.72021	GPU=0.00000	Diff=2003.720215
    Loc(33,0)	CPU=1992.63281	GPU=0.00000	Diff=1992.632812
    Loc(34,0)	CPU=2012.11938	GPU=0.00000	Diff=2012.119385
    Loc(35,0)	CPU=2018.05933	GPU=0.00000	Diff=2018.059326
    Loc(36,0)	CPU=1991.52344	GPU=0.00000	Diff=1991.523438
    Loc(37,0)	CPU=1993.33020	GPU=0.00000	Diff=1993.330200
    Loc(38,0)	CPU=1991.59412	GPU=0.00000	Diff=1991.594116
    Loc(39,0)	CPU=2019.39380	GPU=0.00000	Diff=2019.393799
    Loc(40,0)	CPU=1994.77686	GPU=0.00000	Diff=1994.776855
    Loc(41,0)	CPU=1996.65344	GPU=0.00000	Diff=1996.653442
    Loc(42,0)	CPU=1993.86499	GPU=0.00000	Diff=1993.864990
    Loc(43,0)	CPU=2015.09985	GPU=0.00000	Diff=2015.099854
    Loc(44,0)	CPU=1997.42065	GPU=0.00000	Diff=1997.420654
    Loc(45,0)	CPU=1987.11414	GPU=0.00000	Diff=1987.114136
    Loc(46,0)	CPU=1984.02380	GPU=0.00000	Diff=1984.023804
    Loc(47,0)	CPU=2012.55786	GPU=0.00000	Diff=2012.557861
    Loc(48,0)	CPU=2003.70850	GPU=0.00000	Diff=2003.708496
    Loc(49,0)	CPU=2006.56262	GPU=0.00000	Diff=2006.562622
    Loc(50,0)	CPU=2010.09790	GPU=0.00000	Diff=2010.097900
    Loc(51,0)	CPU=2007.61536	GPU=0.00000	Diff=2007.615356
    Loc(52,0)	CPU=1992.81860	GPU=0.00000	Diff=1992.818604
    Loc(53,0)	CPU=2002.70422	GPU=0.00000	Diff=2002.704224
    Loc(54,0)	CPU=1982.52747	GPU=0.00000	Diff=1982.527466
    Loc(55,0)	CPU=2022.27722	GPU=0.00000	Diff=2022.277222
    Loc(56,0)	CPU=2001.84509	GPU=0.00000	Diff=2001.845093
    Loc(57,0)	CPU=2003.65381	GPU=0.00000	Diff=2003.653809
    Loc(58,0)	CPU=2012.68188	GPU=0.00000	Diff=2012.681885
    Loc(59,0)	CPU=1994.68628	GPU=0.00000	Diff=1994.686279
    Loc(60,0)	CPU=2017.70618	GPU=0.00000	Diff=2017.706177
    Loc(61,0)	CPU=1993.10938	GPU=0.00000	Diff=1993.109375
    Loc(62,0)	CPU=2036.02258	GPU=0.00000	Diff=2036.022583
    Loc(63,0)	CPU=2006.94653	GPU=0.00000	Diff=2006.946533
    Loc(64,0)	CPU=2003.39282	GPU=0.00000	Diff=2003.392822
    Loc(65,0)	CPU=1972.17664	GPU=0.00000	Diff=1972.176636
    Loc(66,0)	CPU=1990.85706	GPU=0.00000	Diff=1990.857056
    Loc(67,0)	CPU=2003.34399	GPU=0.00000	Diff=2003.343994
    Loc(68,0)	CPU=2014.35437	GPU=0.00000	Diff=2014.354370
    Loc(69,0)	CPU=2015.83765	GPU=0.00000	Diff=2015.837646
    Loc(70,0)	CPU=1992.88477	GPU=0.00000	Diff=1992.884766
    Loc(71,0)	CPU=1985.77124	GPU=0.00000	Diff=1985.771240
    Loc(72,0)	CPU=1989.29761	GPU=0.00000	Diff=1989.297607
    Loc(73,0)	CPU=2012.30798	GPU=0.00000	Diff=2012.307983
    Loc(74,0)	CPU=2009.36536	GPU=0.00000	Diff=2009.365356
    Loc(75,0)	CPU=1981.96594	GPU=0.00000	Diff=1981.965942
    Loc(76,0)	CPU=1997.63953	GPU=0.00000	Diff=1997.639526
    Loc(77,0)	CPU=2009.42236	GPU=0.00000	Diff=2009.422363
    Loc(78,0)	CPU=1993.30200	GPU=0.00000	Diff=1993.302002
    Loc(79,0)	CPU=1999.61621	GPU=0.00000	Diff=1999.616211
    Loc(80,0)	CPU=1996.50671	GPU=0.00000	Diff=1996.506714
    Loc(81,0)	CPU=1999.69434	GPU=0.00000	Diff=1999.694336
    Loc(82,0)	CPU=2021.29834	GPU=0.00000	Diff=2021.298340
    Loc(83,0)	CPU=1994.06824	GPU=0.00000	Diff=1994.068237
    Loc(84,0)	CPU=1996.23657	GPU=0.00000	Diff=1996.236572
    Loc(85,0)	CPU=2004.75378	GPU=0.00000	Diff=2004.753784
    Loc(86,0)	CPU=1994.15723	GPU=0.00000	Diff=1994.157227
    Loc(87,0)	CPU=2012.92725	GPU=0.00000	Diff=2012.927246
    Loc(88,0)	CPU=1999.31653	GPU=0.00000	Diff=1999.316528
    Loc(89,0)	CPU=2002.83374	GPU=0.00000	Diff=2002.833740
    Loc(90,0)	CPU=1988.23853	GPU=0.00000	Diff=1988.238525
    Loc(91,0)	CPU=2005.37439	GPU=0.00000	Diff=2005.374390
    Loc(92,0)	CPU=2037.14099	GPU=0.00000	Diff=2037.140991
    Loc(93,0)	CPU=2010.84180	GPU=0.00000	Diff=2010.841797
    Loc(94,0)	CPU=2017.66699	GPU=0.00000	Diff=2017.666992
    Loc(95,0)	CPU=1994.46619	GPU=0.00000	Diff=1994.466187
    Loc(96,0)	CPU=1990.31714	GPU=0.00000	Diff=1990.317139
    Loc(97,0)	CPU=1986.71008	GPU=0.00000	Diff=1986.710083
    Loc(98,0)	CPU=2008.22083	GPU=0.00000	Diff=2008.220825
    Loc(99,0)	CPU=2000.99719	GPU=0.00000	Diff=2000.997192
Total Errors = 128000000
FAILED
Press <Enter> to Quit...
Hi, Have you solved it now?
