I am using cudnn-frontend to piece together custom internal networks using C++.
I have successfully chained single one-channel convolutions, and multiple channel inputs. I have not been successful when output channels to any graph is not 1. When trying various combinations of dimensions and strides for image, filter, and output, sometimes I get error: Error: CUDNN_STATUS_BAD_PARAM; Reason: 0 != wDimA[0] % g. Any hints on what that means?
Hi @westwood ,
can you help us with the reproducible snippet?
I will work on a more exacting snippet, but it is essentially the first TEST_CASE in cudnn-frontend/samples/cpp/convolution/fprop.cpp with n = 1, c = 1, h = 64, w = 64, r = s = 3, and k = 2. I find this error in the loop over image and filter dimensions and strides. Worse though, I never find a correct output of the convolution. I have also looped over setting dimensions and strides for the y_tensor, no luck. I can however find correct results when k = 1 and c != 1, and various h = w, r = s sizes.
- Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
- Permission is hereby granted, free of charge, to any person obtaining a
- copy of this software and associated documentation files (the “Software”),
- to deal in the Software without restriction, including without limitation
- the rights to use, copy, modify, merge, publish, distribute, sublicense,
- and/or sell copies of the Software, and to permit persons to whom the
- Software is furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- DEALINGS IN THE SOFTWARE.
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored “-Wsuggest-override”
#pragma GCC diagnostic ignored “-Wunused-function”
include <cudnn_frontend.h>
include <helpers.h>
#pragma GCC diagnostic pop
std::vector <int64_t> formDim (const std::vector <int64_t> dims, unsigned dimForm)
auto n = dims [0],
c = dims [1],
h = dims [2],
w = dims [3];
switch (dimForm)
// nk c hr ws
case 0: {return std::vector <int64_t> ({n, c, h, w}); break;} // idim, kdim main
case 1: {return std::vector <int64_t> ({n, c, w, h}); break;}
case 2: {return std::vector <int64_t> ({n, h, c, w}); break;}
case 3: {return std::vector <int64_t> ({n, h, w, c}); break;}
case 4: {return std::vector <int64_t> ({n, w, h, c}); break;}
case 5: {return std::vector <int64_t> ({n, w, c, h}); break;}
case 6: {return std::vector <int64_t> ({c, n, h, w}); break;}
case 7: {return std::vector <int64_t> ({c, n, w, h}); break;}
case 8: {return std::vector <int64_t> ({c, h, n, w}); break;}
case 9: {return std::vector <int64_t> ({c, h, w, n}); break;}
case 10: {return std::vector <int64_t> ({c, w, h, n}); break;}
case 11: {return std::vector <int64_t> ({c, w, n, h}); break;}
case 12: {return std::vector <int64_t> ({h, c, n, w}); break;}
case 13: {return std::vector <int64_t> ({h, c, w, n}); break;}
case 14: {return std::vector <int64_t> ({h, w, c, n}); break;}
case 15: {return std::vector <int64_t> ({h, w, n, c}); break;}
case 16: {return std::vector <int64_t> ({h, n, c, w}); break;}
case 17: {return std::vector <int64_t> ({h, n, w, c}); break;}
case 18: {return std::vector <int64_t> ({w, c, n, h}); break;}
case 19: {return std::vector <int64_t> ({w, c, h, n}); break;}
case 20: {return std::vector <int64_t> ({w, h, c, n}); break;}
case 21: {return std::vector <int64_t> ({w, h, n, c}); break;}
case 22: {return std::vector <int64_t> ({w, n, h, c}); break;}
case 23: {return std::vector <int64_t> ({w, n, c, h}); break;}
default:
std::cout << "WARNING hit default dim at kind = " << dimForm << std::endl;
return std::vector <int64_t> ({1, 1, 1, 1});
std::vector <int64_t> formStride (const std::vector <int64_t>& dims, unsigned kind)
// for kernel k c r s, must return 1, 1, s * c, c
int64_t k = dims [0],
c = dims [1],
r = dims [2],
s = dims [3];
switch (kind)
{ // k (n) c r (h) s (w)
case 0: {return std::vector <int64_t> ({1, k, k * c, k * c * r}); break;}
case 1: {return std::vector <int64_t> ({1, k, k * c * s, k * c }); break;} // main kstride
case 2: {return std::vector <int64_t> ({1, k * r, k, k * c * r}); break;}
case 3: {return std::vector <int64_t> ({1, k * r * s, k, k * r }); break;}
case 4: {return std::vector <int64_t> ({1, k * s, k * c * s, k }); break;}
case 5: {return std::vector <int64_t> ({1, k * r * s, k * s, k }); break;}
case 6: {return std::vector <int64_t> ({c, 1, k * c, k * c * r}); break;}
case 7: {return std::vector <int64_t> ({c, 1, k * c * s, k * c }); break;}
case 9: {return std::vector <int64_t> ({c * r, 1, c, k * c * r}); break;}
case 8: {return std::vector <int64_t> ({c * r * s, 1, c, c * r }); break;}
case 10: {return std::vector <int64_t> ({c * s, 1, k * c * s, c, }); break;}
case 11: {return std::vector <int64_t> ({c * r * s, 1, c * s, c, }); break;}
case 12: {return std::vector <int64_t> ({r, r * k, 1, r * k * c}); break;}
case 13: {return std::vector <int64_t> ({r, r * k * s, 1, r * k }); break;}
case 14: {return std::vector <int64_t> ({r * c, r, 1, r * c * k}); break;}
case 15: {return std::vector <int64_t> ({r * c * s, r, 1, r * c }); break;}
case 16: {return std::vector <int64_t> ({r * s, r * s * k, 1, r }); break;}
case 17: {return std::vector <int64_t> ({r * s * c, r * s, 1, r }); break;}
case 18: {return std::vector <int64_t> ({s, s * k, s * k * c, 1 }); break;}
case 19: {return std::vector <int64_t> ({s, s * k * r, s * k, 1 }); break;}
case 20: {return std::vector <int64_t> ({s * c, s, s * c * k, 1 }); break;}
case 21: {return std::vector <int64_t> ({s * c * r, s, s * c, 1 }); break;}
case 22: {return std::vector <int64_t> ({s * r, s * r * k, s, 1 }); break;}
case 23: {return std::vector <int64_t> ({s * r * c, s * r, s, 1 }); break;} // main istride
default:
std::cout << "WARNING hit default at kind = " << kind << std::endl;
void valsToSurface (std::vector & valArray, Surface & to)
auto numElts = valArray.size ();
for (size_t idx = 0; idx < numElts; ++idx)
to.hostPtr [idx] = valArray [idx];
cudaMemcpy (to.devPtr, to.hostPtr, size_t (sizeof (to.hostPtr [0]) * numElts), cudaMemcpyHostToDevice);
void img2Surface (Surface & to)
std::vector img ({1,-1,2,-2,3,-3,4,-4,5,-5,6,-6,7,-7,8,-8,9,-9,10,-10,11,-11,12,-12,13,-13,14,-14,15,-15,16,-16,17,-17,18,-18,19,-19,20,-20,21,-21,22,-22,23,-23,24,-24,25,-25,26,-26,27,-27,28,-28,29,-29,30,-30,31,-31,32,-32});
valsToSurface (img, to);
void kern2Surface (Surface & to)
std::vector kern ({5,-4,4,-3,3,-2,2,-1,1,-9,9,-8,8,-7,7,-6,6,-5});
valsToSurface (kern, to);
void zero2Surface (Surface & to)
std::vector from (to.n_elems, 0.0);
valsToSurface (from, to);
unsigned setShowNCompare (const Surface & s, unsigned idim, unsigned kdim, unsigned istride, unsigned kstride)
std::vector to;
cudaMemcpy (s.hostPtr, s.devPtr, size_t (sizeof (s.hostPtr [0]) * s.n_elems), cudaMemcpyDeviceToHost);
cudaDeviceSynchronize();
for (int64_t sidx = 0; sidx < s.n_elems; ++sidx)
float val = s.hostPtr [sidx];
to.push_back (val);
std::vector control ({-3, 60, -52, 77, -69, 94, -86, 12, -30, 135, -123, 156, -144, 177, -165, 24, -54, 219, -207, 240, -228, 261, -249, 36, -78, 303, -291, 324, -312, 345, -333, 48, -102, 387, -375, 408, -396, 429, -417, 60, -126, 471, -459, 492, -480, 513, -501, 72, -150, 555, -543, 576, -564, 597, -585, 84, -207, 402, -397, 416, -411, 430, -425, 60, -6, -43, 28, -49, 34, -55, 40, 24, -15, -72, 54, -81, 63, -90, 72, 48, -27, -108, 90, -117, 99, -126, 108, 72, -39, -144, 126, -153, 135, -162, 144, 96, -51, -180, 162, -189, 171, -198, 180, 120, -63, -216, 198, -225, 207, -234, 216, 144, -75, -252, 234, -261, 243, -270, 252, 168, -54, -85, 73, -88, 76, -91, 79, 228});
unsigned count = 0;
// set intersection is easier match than identical vector
#if 1
std::multiset lclcontrol (control.begin (), control.end ());
std::multiset toSet (to.begin (), to.end ());
std::vector intersection;
std::set_intersection (lclcontrol.begin (), lclcontrol.end (), toSet.begin (), toSet.end (),
std::back_inserter (intersection));
count = intersection.size ();
#else
for (size_t toIdx = 0; toIdx < to.size (); ++toIdx)
if (to [toIdx] == control [toIdx])
++count;
endif
return count;
unsigned runFor (unsigned idimForm, unsigned kdimForm, unsigned istrideForm, unsigned kstrideForm)
// most of this code is from frontend/samples/cpp/convolutions.cpp
namespace fe = cudnn_frontend;
// n = batch
// c = input channels
// h = height
// w = width
// k = output channels
// r = kernel height
// s = kernel width
int64_t n = 1, c = 1, h = 8, w = 8, k = 2, r = 3, s = 3;
auto build_new_graph = [&](cudnnHandle_t handle) {
auto graph = std::make_sharedfe::graph::Graph();
graph->set_io_data_type(fe::DataType_t::FLOAT).set_compute_data_type(fe::DataType_t::FLOAT);
std::vector <int64_t> idims = formDim ({n, c, h, w}, idimForm);
auto X = graph->tensor(fe::graph::Tensor_attributes()
.set_name("image")
// .set_dim({n, c, h, w})
.set_dim(idims)
// .set_stride({c * h * w, 1, c * w, c}));
.set_stride(formStride (idims, istrideForm)));
std::vector <int64_t> kdims = formDim ({k, c, r, s}, kdimForm);
auto W = graph->tensor(fe::graph::Tensor_attributes()
.set_name("filter")
// .set_dim({k, c, r, s})
.set_dim(kdims)
// .set_stride({c * r * s, 1, c * s, c}));
.set_stride(formStride (kdims, kstrideForm)));
auto conv_options =
fe::graph::Conv_fprop_attributes().set_padding({1, 1}).set_stride({1, 1}).set_dilation({1, 1});
auto Y = graph->conv_fprop(X, W, conv_options);
Y->set_output(true);
REQUIRE(graph->validate().is_good());
REQUIRE(graph->build_operation_graph(handle).is_good());
REQUIRE(graph->create_execution_plans({fe::HeurMode_t::A}).is_good());
REQUIRE(graph->check_support(handle).is_good());
REQUIRE(graph->build_plans(handle).is_good());
return std::make_tuple(graph, X, W, Y);
cudnnHandle_t handle;
checkCudnnErr(cudnnCreate(&handle));
auto [graph, X, W, Y] = build_new_graph(handle);
Surface x_tensor(n * c * h * w, false);
Surface w_tensor(k * c * r * s, false);
Surface y_tensor(n * k * h * w, false); // Should be p, q.
img2Surface (x_tensor);
kern2Surface (w_tensor);
zero2Surface (y_tensor);
std::unordered_map<int64_t, void*> variant_pack = {
{X->get_uid(), x_tensor.devPtr}, {W->get_uid(), w_tensor.devPtr}, {Y->get_uid(), y_tensor.devPtr}};
Surface<int8_t> workspace(graph->get_workspace_size(), false);
std::cout << *graph << std::endl;
REQUIRE(graph->execute(handle, variant_pack, workspace.devPtr).is_good());
unsigned match = setShowNCompare (y_tensor, idimForm, kdimForm, istrideForm, kstrideForm);
cudnnDestroy (handle);
return match;
int main (int argc, char* argv )
unsigned idim = atoi (argv [1]),
kdim = atoi (argv [2]),
istride = atoi (argv [3]),
kstride = atoi (argv [4]);
std::cout << runFor (idim, kdim, istride, kstride) << " exit good" << std::endl;
return 0;
The control comes from match in our tool’s use of tensorflow. I run using a shell script that loops over idim, kdim, istrides, kstrides. Looks like it is going to be another 40 or so hours, but best match so far is 22. I expect to match 2 * 6 * 6 due to valid region padding.
toNV.tar.gz (825 Bytes)
Tarred cpp and script for convenience
We do a convolution not correlation in our networks. My management has asked to reproduce inputs and outputs in tensorflow. Here is script:
import tensorflow.python.keras.layers as Layer
from tensorflow.python.keras.models import Model
from tensorflow.python.keras.layers import Input
import numpy as np
image = np.array ([[ 1, -1, 2, -2, 3, -3, 4, -4],
[ 5, -5, 6, -6, 7, -7, 8, -8],
[ 9, -9, 10, -10, 11, -11, 12, -12],
[13, -13, 14, -14, 15, -15, 16, -16],
[17, -17, 18, -18, 19, -19, 20, -20],
[21, -21, 22, -22, 23, -23, 24, -24],
[25, -25, 26, -26, 27, -27, 28, -28],
[29, -29, 30, -30, 31, -31, 32, -32]], dtype = np.float32)
weights = [np.array ([[[[-4, 5]],
[[-3, 4]],
[[-2, 3]]],
[[[-1, 2]],
[[-9, 1]],
[[-8, 9]]],
[[[-7, 8]],
[[-6, 7]],
[[-5, 6]]]], dtype = np.float32), np.array ([0,0], dtype = np.float32)]
control_answer = np.array ([-3, 60, -52, 77, -69, 94, -86, 12, -30, 135, -123, 156, -144, 177, -165, 24, -54, 219, -207, 240, -228, 261, -249, 36, -78, 303, -291, 324, -312, 345, -333, 48, -102, 387, -375, 408, -396, 429, -417, 60, -126, 471, -459, 492, -480, 513, -501, 72, -150, 555, -543, 576, -564, 597, -585, 84, -207, 402, -397, 416, -411, 430, -425, 60, -6, -43, 28, -49, 34, -55, 40, 24, -15, -72, 54, -81, 63, -90, 72, 48, -27, -108, 90, -117, 99, -126, 108, 72, -39, -144, 126, -153, 135, -162, 144, 96, -51, -180, 162, -189, 171, -198, 180, 120, -63, -216, 198, -225, 207, -234, 216, 144, -75, -252, 234, -261, 243, -270, 252, 168, -54, -85, 73, -88, 76, -91, 79, 228], dtype = np.float32)
batch = 1
imageWidth = 8
imageHeight = 8
inputChannels = 1
outputChannels = 2
weightsWidth = 3
weightsHeight = 3
image_shape = (imageWidth, imageHeight, inputChannels)
inputs = Input (shape = image_shape, name = “image”)
conv = Layer.Conv2D (filters = outputChannels,
kernel_size = [weightsWidth, weightsHeight],
padding = “SAME”,
kernel_regularizer = None,
trainable = False,
activation = None,
dtype = “float32”,
input_shape = image_shape)
model = Model (inputs, conv (inputs))
model.set_weights (weights)
image = np.expand_dims (image, axis = 0)
image = np.expand_dims (image, axis = 3)
out = model.predict (image)
out = out [0,:,:,(1,0)].ravel ()
print (out)
match = 0
noMatch = 0
for idx in range (len (control_answer)):
outElt = out [idx]
ctrlElt = control_answer [idx]
if outElt == ctrlElt:
match = match + 1
else:
noMatch = noMatch + 1
print (“match %s: , noMatch: %s” % (match, noMatch))
control.tar.gz (1.2 KB)
