What does "Reset the board to boot from internal eMMC" exactly means?
Hello everyone,
I’m currently in the process of flashing the Jetpack OS to a Jetson Nano using the reComputer J1010 board via the command line and need some guidance.
I’ve reached the final part of the instructions where I need to “Reset the board to boot from internal eMMC,” but I’m unsure about how to proceed with this step.
Is the process simply to unplug the board from power, remove the jumper, and then plug it back in? Or is there a reset button on the board? If there is a button, and using it turns the board straight back on, when should I remove the jumper? From my understanding, it has to be removed when the board is off.
Any advice or guidance would be greatly appreciated!
here is the official documentation: J101 carrier Board | Seeed Studio Wiki
Thank you in advance!
YES. Exactly.
Nothing complicated here.
