According to the ConnectX-8 SuperNIC data manual, it supports two 400G Ethernet ports. Does “Supports up to 8 split ports” mean that each 400G port can be split into four 100G physical ports, totaling eight 100G physical Ethernet split ports?
Yes, that’s correct. Each 400G port on the ConnectX-8 can be split into four 100G physical ports, so with two 400G ports, you get up to eight 100G split ports in total.
