What does the input voltage affect?
Currently we have our Xavier plugged into a 19V power supply, however 19V is an “unusual” voltage. In embedded environments 12/15/24V are much more common rails. What would be the quantitative impact of us dropping down to 15V? Not just “it wont get the most of out of ___”, but actually the quantitative difference?
Hi, the input voltage range is 9V ~ 20V. Lower input voltage will cause more input current.
Alot of comments on this forum say that reducing the voltage will limit the CPU/GPU is this not true?
No, it won’t.
Excellent, Thank You! For sanctity sake is there any documentation on this?
Please refer to OEM DG and module datasheet in DLC: https://developer.nvidia.com/embedded/downloads
