Can somebody explain how the nvidia provided jpeg decoding/encoding plugin work on the Jetson TK1? I can see that nvidia has provided a libjpeg.so and a gstreamer plugin library/source as well.
There is no mention in the TRM about any dedicated hardware block in Tegra K1 processor for jpeg decode/encode. Then how is it hardware accelerated. Does it use CUDA, or Neon or GLSL or any other techniques?
I think the jpeg situation is similar to video and 3D. TRM doesn’t say much but still you have a SW API that you can use to perform the needed operations. The datasheet do list the capabilities of the jpeg decoding and encoding.
Hi kulve, could you point out which datsheet you are referring to? The multimedia user guide only explains how to use the gstreamer plugin. I havent seen any performance characteristics mentioned.
I have a source that can provide JPEG data at high framerates. I’m trying to decode the data using gstreamer. I noticed that there are 3 gstreamer plugins that can handle jpeg.
jpegdec
nvjpegdec
nv_omx_jpegdec
As far as I have tested jpegdec seems to be faster than nvjpegdec. Thats why I’m trying to understand how nvidia’s jpeg decoder works. This is the pipeline I’m using :
Thats a nice suggestion kulve. I have already maximized both the GPU clocks and CPU core clocks. Still did not notice any big improvement in performance.
Also I tried your suggestion to decode a file. But the sources I can find online are all either low resolution or has low framerate. So I’m unable to see any difference between the software decoder and the hardware accelerated decoder. The camera I’m using can generate UltraHD jpeg data at 30 fps. I’m able to get the JPEG data at 30 fps using gstreamer. Only while decoding, the framerates drop drastically. So using a video node is not an issue here.
A similar problem with encode jpeg.
The command
for i in seq 1 1000; do
gst-launch-0.10 filesrc location=./img_2592x1944_pitch2592 blocksize=5038848 !
“video/x-raw-gray, bpp=8, width=(int)2592, height=(int)1944, framerate=(fraction)1/1, format=(fourcc)I420” !
jpegenc !
fakesink -e
done
It is performed for 1m24s seconds. The command
nvjpegenc !
fakesink -e
done
It is performed for 2m45s seconds.
It is clear that for some time it takes to load the file. But still the standard is faster encode nvidia encode.
