What driver or modules are needed for hardware rendering on Jetson devices?
I’m trying to use hardware rendering on my Jetson AGX Orin device, and I’ve encountered some issues:
  1. I noticed that the kernel has loaded tegra_drm instead of nvidia_drm, but my environment contains both nvidia-drm.ko and nvidia-modeset.ko. Are these kernel modules still needed to be loaded?
  2. The information from executing lsmod is as follows; are there any kernel modules that have not been loaded?
root@p3737-0000-p3701-0005:/sys/module# lsmod
Module                  Size  Used by
snd_soc_tegra210_admaif   131072  1
snd_soc_tegra186_asrc    40960  1
snd_soc_tegra_pcm      16384  1 snd_soc_tegra210_admaif
snd_soc_tegra210_ope    36864  1
snd_soc_tegra186_dspk    20480  2
snd_soc_tegra210_mixer    49152  1
snd_soc_tegra210_adx    32768  4
snd_soc_tegra210_afc    20480  6
snd_soc_tegra186_arad    28672  2 snd_soc_tegra186_asrc
snd_soc_tegra210_amx    36864  4
snd_soc_tegra210_mvc    20480  2
snd_soc_tegra210_dmic    20480  4
snd_soc_tegra210_sfc    61440  4
snd_soc_tegra210_i2s    28672  6
snd_soc_tegra210_ahub  1273856  3 snd_soc_tegra210_ope,snd_soc_tegra210_sfc
tegra210_adma          24576  0
nvvrs_pseq_rtc         16384  0
spidev                 28672  0
snd_soc_tegra_machine_driver    16384  0
snd_soc_tegra_utils    32768  2 snd_soc_tegra210_admaif,snd_soc_tegra_machine_driver
snd_soc_tegra_audio_graph_card    16384  0
snd_soc_audio_graph_card    20480  1 snd_soc_tegra_audio_graph_card
snd_soc_simple_card_utils    28672  3 snd_soc_tegra_audio_graph_card,snd_soc_audio_graph_card,snd_soc_tegra_utils
tegra234_oc_event      16384  0
crct10dif_ce           20480  1
tegra23x_perf_uncore    20480  0
tpm_ftpm_tee           16384  0
nvpmodel_clk_cap       16384  0
tegra_aconnect         16384  0
tegra_mce              28672  1 tegra23x_perf_uncore
tegra_cactmon_mc_all    16384  0
thermal_trip_event     16384  0
mttcan                 69632  0
snd_soc_rt5640        126976  1
can_dev                40960  1 mttcan
snd_soc_rl6231         16384  1 snd_soc_rt5640
tegra234_aon           57344  1
snd_hda_codec_hdmi     69632  1
pwm_tegra_tachometer    16384  0
snd_hda_tegra          16384  0
snd_hda_codec         139264  2 snd_hda_codec_hdmi,snd_hda_tegra
at24                   24576  0
snd_hda_core          102400  3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_tegra
pwm_tegra              20480  1
spi_tegra114           28672  0
lm90                   28672  0
nvidia_vrs_pseq        16384  0
xhci_pci               24576  0
xhci_pci_renesas       16384  1 xhci_pci
i2c_nvvrs11            16384  0
nvethernet           1175552  0
nvidia               1597440  0
mc_hwpm                16384  0
host1x_fence           24576  0
nvpps                  32768  2 mttcan,nvethernet
tegra_dce             110592  2 nvidia
tegra_bpmp_thermal     16384  0
tegra_pcie_dma_test    20480  0
tegra_pcie_edma        24576  1 tegra_pcie_dma_test
nvhost_vi5             20480  0
nvhost_isp5            16384  0
nvhost_nvcsi_t194      16384  0
tegra_camera          249856  3 nvhost_isp5,nvhost_nvcsi_t194,nvhost_vi5
v4l2_dv_timings        36864  1 tegra_camera
nvhost_nvcsi           24576  1 tegra_camera
tegra_camera_platform    24576  4 nvhost_isp5,nvhost_nvcsi_t194,tegra_camera,nvhost_vi5
capture_ivc            28672  1 tegra_camera
tegra_camera_rtcpu    229376  2 capture_ivc,tegra_camera
ivc_bus                24576  2 capture_ivc,tegra_camera_rtcpu
governor_userspace     16384  0
hsp_mailbox_client     20480  2 ivc_bus,tegra_camera_rtcpu
ivc_ext                20480  2 ivc_bus,capture_ivc
v4l2_fwnode            20480  1 tegra_camera
v4l2_async             24576  2 v4l2_fwnode,tegra_camera
videobuf2_dma_contig    24576  1 tegra_camera
videobuf2_memops       20480  1 videobuf2_dma_contig
videobuf2_v4l2         32768  1 tegra_camera
videobuf2_common       65536  4 videobuf2_dma_contig,videobuf2_v4l2,tegra_camera,videobuf2_memops
nvhost_capture         20480  2 nvhost_isp5,nvhost_vi5
videodev              266240  4 v4l2_async,videobuf2_v4l2,tegra_camera,videobuf2_common
nvhost_nvdla          110592  0
tsecriscv              36864  1 nvidia
nvhost_pva            167936  0
mc                     61440  4 videodev,videobuf2_v4l2,tegra_camera,videobuf2_common
tegra_drm             307200  0
host1x_nvhost          40960  9 nvhost_isp5,nvhost_nvcsi_t194,nvidia,tegra_camera,nvhost_nvdla,nvhost_capture,nvhost_nvcsi,nvhost_pva,nvhost_vi5
tegra_wmark            16384  0
nvhwpm                139264  4 mc_hwpm,tegra_drm,nvhost_nvdla,nvhost_pva
tegra_se               57344  0
cec                    57344  1 tegra_drm
crypto_engine          16384  1 tegra_se
drm_kms_helper        303104  1 tegra_drm
pwm_fan                20480  0
nvgpu                2793472  0
governor_pod_scaling    45056  0
nvmap                 237568  1 nvgpu
nvsciipc               24576  1 nvmap
host1x                208896  7 host1x_nvhost,host1x_fence,tegra_se,nvgpu,tegra_drm,nvhost_nvdla,nvhost_pva
mc_utils               16384  3 nvidia,nvgpu,tegra_camera_platform
ina3221                24576  0
fuse                  139264  1
drm                   630784  4 drm_kms_helper,nvidia,tegra_drm
nfnetlink              20480  1
ipv6                  499712  50
nvme                   49152  0
nvme_core             110592  1 nvme
tegra_xudc             45056  0
pcie_tegra194          40960  0
phy_tegra194_p2u       16384  14
  1. I find it difficult to locate resources related to Tegra. Is there an introduction to the graphics framework and components associated with Tegra? Can I get some help?
Insufficient installation of some files, resolved
