What happened to my Jetson Xavier device, it can’t start properly with the following startup message “timeout in tegra_cec_native_write_1:172.”; I just copied a file to the system, failed to decompress the file, and the system suggested that there might be insufficient disk space. Then, I restarted the system, but I could not log in normally, and then I turned off the power and started again, and the following error occurred, the device only used HDMI interface, other interfaces are not connected to any device.
Lacking of disk space will possibly make desktop graphic fails to launch.
Use keyboard ctrl + alt + F1 ~ F6 shall still be able to use the command line to control the device. Reduce some disk space and reboot shall bring the desktop back.
