Hi, I have a question regarding how much memory processes running on an MPS enabled GPU can use.
My scenario is where there are two different processes each using tensorflow to run on the GPU. The GPU is configured to use MPS so two processes can run run concurrently.
What happens if each tensorflow models is 5 GB (so two models will need 10 GB memory in total) but the GPU only has 8GB available?
Thank you,
Sujan
