I want to work on a container with the TX2. What image should I be using? The l4t image or a Linux Ubuntu image. My program doesn’t need GPU support, and after finishing I plan to port it onto the TX2.
Sorry for the late response, is this still an issue to support? Thanks
It’s recommended to use L4T Base image for your use case.
Since you may still need some hardware support (ex. display, USB, …), you can get better support with the L4T image.
