I run sudo /opt/nvidia/jetson-io/jetson-io.py
Select Configure 40-pin expansion header
If you select Export as Device-Tree Overlay
It is saved in the following file under /boot.
Can you explain what this is?
Thank you.
Thank you.
hello neuezeal,
it’s an overlay device tree blob.
you may refer to [url]https://www.kernel.org/doc/Documentation/devicetree/overlay-notes.txt[/url] for reference.
thanks
